Old 06-14-2012, 03:39 PM
freakaftr8's Avatar
Convergence freak!
CTC-40 focus issue
Im sure this has been covered a hundred times, but without a sams, the focus is all the way to the right yet it's still out of focus a touch.
What am I looking for, a resistor, a diode?
Thanks guys
Old 06-14-2012, 03:47 PM
Usually it's a drifted resistor, they like to go up in value, most of the time.
Old 06-14-2012, 05:10 PM
freakaftr8's Avatar
Convergence freak!
Does this set use one of those "barber pole" resistors the ctc-16/17 and others use?
Old 06-14-2012, 05:23 PM
nope. check and see if there is a wire that bridges a 3.3 meg, follow the focus lead to find it. you can clip the wire if it will not focus in and you are going fully low voltage. Thats what my service manual says anyway...
Old 06-15-2012, 12:09 PM
kx250rider's Avatar
REAL TVs have TUBES!
Check the CRT socket. Those get leaky, and you can tell by the focus pin being green and corroded. Usually once that has happened, you need to replace the socket, but you might get lucky if it just started (if that's even the problem here).
Charles
Old 06-15-2012, 12:49 PM
freakaftr8's Avatar
Convergence freak!
CRT socket is good. Pins are clean too.
And I'm not seeing that 3.3meg resistor either. I did however find a 66 meg barber pile resistor. Replaced it for good measure. No difference.
Old 06-15-2012, 01:10 PM
should be right off the center lug of the focus pot. can you check the focus voltage at the CRT pin, the man says 5100v there is a 4.7 meg 2 watt resistor in series with focus pin, may want to check that as well
Old 06-15-2012, 01:14 PM
freakaftr8's Avatar
Convergence freak!
well I might have run into a small (well moderate) snag... The Flyback does not look happy. A bit of melted wax on the bottom.. The core is a hair loose on the lug as well.
freakaftr8's Avatar
Convergence freak!
How do you test to see like how you do on tube sets off the horiz cathode current?
Old 06-15-2012, 02:19 PM
hmmm scr, don't know about that. what is the HV at?
Old 06-15-2012, 02:23 PM
I am sure it does not matter but whats the line swith set to normal or High?
Old 06-15-2012, 02:36 PM
freakaftr8's Avatar
Convergence freak!
Normal. What's this switch do anyway?
Old 06-15-2012, 02:38 PM
freakaftr8's Avatar
Convergence freak!
Darn. Missing my probe
Old 06-15-2012, 03:21 PM
freakaftr8's Avatar
Convergence freak!
Well I found the 3.3m resistor. Clipped the wire across it. Measures 3.5m powered it up and the focus is now worse clipped and won't focus in well. Is .2 m enough to cause problems?
Old 06-15-2012, 03:25 PM
freakaftr8's Avatar
Convergence freak!
actually I answered my own dumb question, lol, the resistor is not used in this application bridged. This would tell me I have low voltage im assuming. Wonder what my HV is running at.. Hmmm
