Old 06-24-2012, 04:07 PM
mrflex65's Avatar
mrflex65 mrflex65 is offline
Zenith AC/DC Radio
Found this old zenith AC/DC radio at a yard sale for $2
Looks like it's been sitting in a barn for quite awhile,the plastic dial window is warped beyond recognition (dial still works though),the knobs aren't much better and looks like the back cover is missing But other than a few scuff marks,the cabinet is in pretty good shape! i have no idea how old this set is.Can anybody help me ID this little gem and is it worth restoring?
Regards.
"IPC 610 Class E & J STD-001 Certified"
Old 06-24-2012, 04:18 PM
mrflex65's Avatar
I've never seen this happen to a can cap before....
Also there was a big chunk of a mud daubers nest that was sitting at the bottom of the cabinet (probably the same vintage as the set)
Old 06-25-2012, 02:24 AM
Definitely 1940's era. Later on I'll try to look it up in my collectors guide and see if I can get a more precise date. Those dial plastics were almost universal and tend to be bad if the set was not stored in a REALLY good environment all it's life. Many types of plastic used back then tend to degrade over time BTW.....
Old 06-25-2012, 02:43 AM
David Roper's Avatar
console lover
I was going to say it looked like something from the immediate postwar period, but then I noticed the bit about 'Consol-Tone'. It's a 1942 model, the 6-D-2614.
tvontheporch.com
Old 06-25-2012, 04:16 AM
Reece's Avatar
Reece Reece is offline
I have a similar model in the same cabinet, but it has a short wave band, also. Unfortunately, somebody tried to refinish it with a belt sander and they got down through the veneer in some places. It's been sitting waiting for me for years to reveneer it.
You can buy a new dial cover or make your own. Bill Turner sells a kit for making them.
http://www.dialcover.com/dialcovers.html
Reece
Old 06-25-2012, 07:37 AM
mrflex65's Avatar
Thanks guy's for the help! Do you think they make a repo of the back cover and the can cap?Haven't had much time to do a search on it yet.
Old 06-25-2012, 05:38 PM
mrflex65's Avatar
Ok, the cleanup has begun!
The knobs crumbled upon removal which i kinda figured what would happen.
Chassis cleaned up pretty nice (except for the top of the I.F. coils) with alittle compressed air and various paintbrushes and a ammonia/water solution and cotton balls Now i have to locate a sams folder and recap it and a new line cordThe only thing i've done to cabinet so far was to wipe it down with a little lemon oil....
Old 06-25-2012, 06:20 PM
Dah-Yum...Talk about a Silk Purse from a Sow's Ear...1/8 or even 1/16" Plexiglass oughta do the trick for the dial window...I'd wager Antique Electronic Supply has suitable knobs, too.
Old 06-25-2012, 06:58 PM
radio63's Avatar
radio63 radio63 is offline
Still Y2K Compliant!
Ancient mud dawbers of the 1940s! LOL! What a great find for $2! It should be a fun project to restore this little set. Hopefully the lemon oil will help the cabinet to look nice again! You may have to reapply, since I'm sure the dry wood will absorb quite a bit.
Gilbert
I don't know anything about ignorance and I could care less about apathy.
www.galaxymoonbeamnightsite.com
Old 06-25-2012, 07:30 PM
...At least they were Dirt Dobbers, & NOT them Mean, l'il Striped Sumbichin' Waspers that'll eat you alive...
Old 06-25-2012, 08:00 PM
mrflex65's Avatar
Well, there were actually two nests in there! The other one fell out when i took the chassis out of the cabinet. Took a hammer to one of them and hit it like three times before it broke in half! More than likely these critters were way before my time.....
Old 06-26-2012, 05:54 AM
Reece's Avatar
If you google "make radio dial cover" you'll find many articles on how to do it. Here's one thread:
http://www.antiqueradios.com/forums/...c.php?t=110419
Reece
Old 06-26-2012, 07:21 AM
mrflex65's Avatar
This is uncharted territory for me! Have you or anybody else here ever try it?
I'm not sure how the wife is going to react to me "cooking" plastic in the oven...
One quick question, do you what this material is stapled to the bottom of the cabinet? I hope it isn't asbestos!
Old 06-26-2012, 07:48 AM
sean's Avatar
sean sean is offline
Renovated Radios has reproduction knobs:
http://www.renovatedradios.com/parts.html
I made a dial cover for a little Zenith radio a few months back. I used the clear plastic from a birthday cake package and made a mold from some masonite. I cut out the shape of the dial cover with a knife and sanded the cutout piece to allow clearance for the plastic between it and the outer piece of masonite. I warmed the oven up on its lowest temperature (something like 200 degrees) and laid a piece of the plastic over the inner piece inside the oven. I bumped up the temperature until I saw the plastic start to droop then I pulled the plastic out and pushed the outer portion of the mold over the plastic and held it together with some weight until it cooled. It turned out pretty good although the size could be adjusted a little bit. One thing that I noticed is the plastic did shrink a little and clouded up when it got to the temperature where it drooped. The cloudiness went away and the plastic became a little thicker than it was before being heated.
BTW, that is asbestos in the bottom of your cabinet. You can either wet it down and remove it or spray it to contain it and leave it there.
Sean - WØKPX
Old 06-26-2012, 08:18 AM
mrflex65's Avatar
Thank you Sean for the info!
I think i'm just gonna wet it down and remove it for safety's sake!
Will it take away from the value of the set if i install the chassis on bare wood or use some other kind of material to set it on?
It's a good thing i was working on this cabinet outside....
