Old 07-15-2012, 12:57 PM
medadandmom medadandmom is offline
gemini tv transmitter power supply
i recently picked up a gemini vc2000 and vc2100 with no cables and no booklet i need to know where to find the required power cables and the red video and audio cables any help would be great
Old 07-15-2012, 10:43 PM
The cables are the same standard ones sold for audio/video anywhere (Wal-mart, Sears, Radio Shack, etc.). The power supplies are 15 volts DC, center pin positive if I remember right. I will look at mine when I can and let you know what they should be. They use very low current so most universal cheap AC adapters set to 12V or higher will probably work OK (the cheap, non-regulated ones).
