Old 08-18-2012, 09:30 PM
Garage sale scorem Trav-ler 9 TR620 transistor
You don't see many of these at garage sales too often.
The guy said it didn't work. Figured it probably need new electrolytic caps, but once I got home found some AA batteries, tried it and it does work.
Model TR620, 625, 630 it says inside the back. Also "Made in USA"
Old 11-11-2012, 01:33 PM
radiodayz's Avatar
radiodayz radiodayz is offline
radiodayz
Maybe a re-badged Channel Master/Sanyo? Looks very similar to horizontal-format 60s Channel Masters (except that they usually have the station dial on the left).
I have one of those around here, somewhere
Old 11-11-2012, 05:46 PM
Kewl !
Old 11-14-2012, 08:23 AM
Those early Trav-lers were USA built.
I picked up a 1960 model Motorola, That has seven plug-in TI transistors.
Built on Augusta Blvd. Even that early, it uses Japanese 'lytics.
Model X16N, it uses a center tapped power supply, to eliminate the output transformer. It has a 39 ohm Quam speaker.
Old 04-05-2013, 03:41 PM
KentTeffeteller's Avatar
Gimpus Stereophilus!
Beautiful set. I love early USA made transistor radios. Trav-lers are uncommon for sure. Interesting set and it has some Japanese parts in it.
