Old 08-27-2012, 12:14 AM
TV-collector's Avatar
TV-collector TV-collector is offline
Question Belmont 21A21 question
Hi,
What are the main differences between the 7GP4 and the 7JP4?
In case that I ever have to interchange them are there changes in
the wiring needed?
Thanks in advance,
TV-Collector
Old 08-27-2012, 04:36 PM
rld-tv01's Avatar
rld-tv01 rld-tv01 is offline
Bottom of this thread discusses 7jp4 vs 7ep4 vs 7gp4
http://videokarma.org/showthread.php?p=3027180
lifted from link:
"come across a Transvision that had a 7JP4 installed in it, worked fair.
7JP4 2nd anode is 5 to 6KV, 7EP4 2nd anode is 2KV.
A 7GP4 is a closer match only requires 3KV, but harder to find than 7JP4. Usually found in Philco 48-700 sets.
Better temp tube is a 5BP4, easier to find than either of the others and is electrically identical to the 7EP4"
Also 7GP4 was used in Philco 48-700 in early versions and Philco substituted 7JP4 in later versions.
Old 08-27-2012, 06:25 PM
If I,m not mistaken the 5BP4 is an electromagnetically deflected tube used in Pre-War sets, the 7JP4 and 7GP4 are Electrostats and completely incompatible.
Old 08-27-2012, 06:30 PM
Never mind, my mistake, I just read that the 5BP4 IS an electrostatic tube!
Old 08-28-2012, 11:59 PM
Hi,
Many thanks for the input!
TV-Collector
