Old 11-23-2012, 07:35 PM
TomRhoads TomRhoads is offline
Rca 811k info
I am restoring a model 811K RCA console radiocirca 1937 .Would like to have information about the fine tuning for the stations My radfio does not have the knob and there is no shaft for it also.The coarse tuning tuning knob andshaft are there,and connected to the variable cap,but I cant tell whatwas used to have fine tuning in the inside of the shaft.Pleasehelp with info ,thanks.
Old 11-23-2012, 09:03 PM
Is there two knobs on the tuner shaft? An outer and inner knob? If so, the tuning cap has a vernier drive on it.
Usually, if there's no reduction of turns, by using the center knob, it means that the grease is all gummed up and preventing the drive from working properly.
Old 11-23-2012, 11:18 PM
Ampico-kid's Avatar
Ampico-kid Ampico-kid is offline
Are you referring to setting the motorized preset station pushbuttons?
Bob
Old 11-24-2012, 10:00 AM
The outer shaft and knob are there ,and connected to the capacitor.The inner knob(fine tuning) is missing andso is the shaft and whatever parts it goes to inside the outer shaft. What parts are missing?
Old 11-24-2012, 01:12 PM
Someone probably tried to free up the gummed up works and lost the parts.
I don't remember the way it went together.
One of RCA's more desirable sets.
Old 11-24-2012, 02:14 PM
Ampico-kid's Avatar
That's kind of a difficult question to answer. That inner "fine tuning" control is attached to several gears. If it weren't such a bear to remove and take apart, I'd shoot you a few picures of the gearing in my set, but ...it's in a very confined and closed in area and it would be very difficult to take a picture and properly show what you'd need to see.
I think your best bet might be to locate a parts chassis and carefully remove the whole tuning gear assembly.
Wish I could be of more help...........Bob
Old 11-24-2012, 02:55 PM
Yeah, an RCA 811 is right up there as a VERY desirable set...
