Old 11-27-2012, 09:40 AM
dnpainting dnpainting is offline
AK Subscriber
GE 46GW948 Rear Projection Questions
Hi All,
My son saw this tv at a yard sale across the street and just had to have it. I new the guy selling it and he had told me that the picture was both hazzy and bright on day scenes and really dark on night scenes, sorry if the description is vague. Anyways, I traded it straight across for a Sony tv to please my son. I hooked it up and saw what he was saying, can't see night scenes and looks like you are looking through scratched glasses on daytime scenes.
I went through the service menu and the convergence adjustments in the service menu, the convergence will adjust. The problem that I can see in the convergence is the Blue, both horizontal and vertical. The convergence lines on blue are wide and fuzzy, not sharp like the red. While in the service mode, the green adjustment grid cannot be adjusted that well. What I mean is it is dished inwards on all 4 sides.
I can take some pics of all this if that will help.
I have the picture adjusted the best I can get it so my son has his tv for after school, for the time being. Both the Bias and Drive adjustments for the 3 colors to get this still bad picture are set at their maximum setting.
Now for the question: Should I start this repair by replacing all the transistors on the convergence boards? I think there were something like 10 transistors in each color.
What else should I check?
Thank you!
Old 11-27-2012, 11:44 AM
DavGoodlin's Avatar
Motorola Minion
I had a similar experience with a Philips. The set I worked on needed 1 or 2 convergence IC's (black multi-pin, mounted on heat sinks) replaced, a "fix-kit" which he got on the internet. That did fix the convergence issue.
The fuzzy picture may be the result of cooling fluid in the lenses being polluted with microbial growth, especially on the CRT faces of blue and green.
I would first try cleaning these out before spending money on the convergence issues. We got the cooling fluid from a local electronics distributor.
see this link
http://videokarma.org/showthread.php?t=254808
Old 11-27-2012, 03:48 PM
AK Subscriber
Got The Bugs Out!
Thank you for the link DavGoodlin, I followed the link on the fluid and did as the instructions said to with looking down the lenses while the TV was on. Here was one problem with the fuzzy picture.
Burnin' A Roach
Picture is not bad at all anymore. I did not know that you could remove the Magnifier Lenses, learn something new everyday.
I still plan on doing a coolant fluid change as the blue and green aren't as sharp as the red.
Old 11-27-2012, 03:50 PM
AK Subscriber
One more question: Is there anything you can do about a burnt screen? The family that owned this before left Charter Cable logo in the top corner and it burnt in.
Here is a pic os the current picture. Not hazzy or wahed out anymore.
