Old 11-30-2012, 08:45 AM
Early B&W? or color?
Here's a postcard advertising TV service using RCA tubes, using a picture of part of the bottom of a chassis.
The puzzle for all you experts is: can the chassis be identified?
File Type: pdf Seeing things - we use RCA postcard.pdf (181.9 KB, 138 views)
Old 11-30-2012, 08:59 AM
It looks like a KCS81, or simular from the 1952-53 era. I see the two 5U4 sockets near the power transformer.
Old 11-30-2012, 10:13 AM
radiotron's Avatar
radiotron radiotron is offline
johnny the raster master!
its a b/w
Looking for zenith cobramatic parts
-johnny the raster master!
Old 11-30-2012, 10:21 AM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
On the upper right side, it appears that there is one ceramic octal socket on that chassis?
Seems out of place on a mass-produced consumer item like a TV set. Usually you only see those on military and industrial gear...
Old 11-30-2012, 11:20 AM
John Marinello's Avatar
<-- "Byron"
Hint: 15-20 electron tubes.
Old 11-30-2012, 12:30 PM
I don't know why they used them, but they did! They were also shock-mounted. They probably got a good buy on them, so why not.
Old 11-30-2012, 02:28 PM
N2IXK's Avatar
Technohippie
Which tube was installed in it? Presumably the shock mounting was for microphonics?
Old 11-30-2012, 04:57 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
I believe, IIRC, it was the Horizontal oscillator. My KCS-47 Fairfield had that arrangement.
Old 11-30-2012, 08:24 PM
I saw that, but there is no reason the text would correspond to the picture.
I suspected B&W anyway.
One more thing - a trimmer cap under the chassis doesn't seem like an optimum design.
Old 11-30-2012, 10:14 PM
cbenham's Avatar
cbenham cbenham is offline
It's not a Muntz--Too many parts.
Cliff
Old 12-01-2012, 05:46 PM
Look at all those wax caps and bumble bees! That will keep you busy recapping this post card.
Old 12-01-2012, 06:09 PM
It looks too crowded for an RCA chassis, I wonder if they added some extra parts to make it look more impressive?
Old 12-01-2012, 06:35 PM
It looks like one of the 5U4's is missing.
I have one of those sets in line to recap. There's a lot of them in there, and 'lytics as well.
Old 12-02-2012, 11:12 AM
kx250rider's Avatar
REAL TVs have TUBES!
Definitely B&W and early 50s; maybe late 40s. I see the horizontal oscillator transformer mounted under the chassis next to the two trimpots for horizontal stab. & linearity, if I recall what those do.
Charles
Old 12-07-2012, 05:05 PM
Penthode's Avatar
Penthode Penthode is offline
Look at the attached. Does it look familiar?
I recognized it as an RCA from the early 50's. It actually is a kcs68 circa 1951. Note the position of the tubes. Incidently I looked to schematic to find that badly mounted trimmer capacitor is actually across the over-coupled transformer link at the input of the first video IF amplifier. And the ceramic tube socket was used by all the RCA's of the period for the horizontal oscillator tube. I believe it was one of the best designed B&W TV sets ever built (apart from that lousy trimmer!)
