Old 12-07-2012, 02:25 PM
BrianSummers's Avatar
BrianSummers BrianSummers is offline
TV Camera Museum Curator
Corrosion on camera bodies
As some of you may know I have a modest collection of ex broadcast TV cameras as part of the collection at www.tvcameramuseum.org
Some of the cameras, those with the lightweight aluminium/magnesium castings, have corrosion of exposed corners and around fittings. It is that white gooey type, rather like what you see on some discharged batteries, often wet to the touch, but the camera is in good storage and in the dry.
My question is how can I minimise this and/or fix it. I don't want to paint the cameras as this would remove originality or to smear with silicon/Vaseline/oil as these would be sure to migrate to the optics causing damage there.
Has anyone any good suggestions?
The camera pictured is a Philips LDK14 in it's flight case, the picture was taken a couple of years ago and it has deteriorated somewhat since, hence this posting.
Old 12-08-2012, 02:42 PM
XDCAM's Avatar
XDCAM XDCAM is offline
White powder
I have never found or heard of that problem, except the Rubber & Pass Filters. I have the White powder problem (But not wet) ! Been asking around and have been told you need to seal the affected area from the air to retard the problem (NAIL POLISH ) .
Old 12-15-2012, 04:42 PM
That's an interesting suggestion, you can get clear nail varnish, I'll give that a try.
The other interesting suggestion I had was to seal the camera in the vacuum bags sold for clothing, bedding, etc? with a pack of silica gel.
They're basically a large zip-lok bag with a valve for attaching your vacuum cleaner hose.
Thanks Brian
Old 03-19-2015, 04:08 PM
XDCAM's Avatar
This might help with our Cameras too. White rust
Phosphoric Acid brush over infected areas with a stiff brush or Acetic Glycolic and the other Citric Acid which is usually much safer to have around the house. Once the surface has been treated then rinse of with water with a dash of dish-washing liquid is a good as it gets.
http://www.planetdiecast.com/index.p...37455&Itemid=0
Old 03-20-2015, 02:25 AM
ppppenguin's Avatar
Bit of a wildcard idea. I wonder if the foam in the flight case is contributing to the corrosion.
Old 03-20-2015, 07:48 AM
XDCAM's Avatar
You are right .But I will try anything too save my Cameras .Nobody has found a solution for this yet ! And it still eating the aluminum/magnesium castings of my Camera .
Old 03-20-2015, 09:30 AM
Celt's Avatar
Celt Celt is offline
Peanut Head
At least it's not the nasty green corrosion that we used to see on 35mm cameras.
Old 03-25-2015, 07:57 AM
john f john f is offline
it could be from the dissimilar metals. galvanic corrosion. i'd loosen the screw a turn or two and coat the head with the clear nail polish then tighten it back up before it dries.
Old 03-31-2015, 10:08 PM
Telecruiser's Avatar
Telecruiser Telecruiser is offline
Try some Armor-All Tire Foam. It comes in an aerosol can. Just spray a little on a rag and apply it. That way you can keep it out of places you don't want it to go. Wipe it on, wipe off the excess, and leave it alone for an hour. I think you will be amazed by the results. Try a little at first. This stuff has silicone in it so nothing will stick to it, including paint. If you want to re-paint it, you will shave to strip it off, but I've found that ordinary paint thinner does a good job. Using this stuff is not a permanent fix, but it lasts about 3-4 years. When it starts to look bad, just wash it with water and reapply when dry. It makes plastics and many other finishes look like new.
