Old 12-07-2012, 07:48 PM
josephdaniel's Avatar
Learning as I go
Crt tester wanted
Is there anyone here in Texas or in Missouri that would have a crt checker that I could borrow I have several tubes that need tested and im going up to Missouri (in Sullivan about an hour from stl) and my parents said that I could bring back one set so long as it wasent too big. I seem to see alot more of them up there and for alot cheaper than here in Texas too!
the only tubes I would need to test would be b&w tubes I would also consider buying one too.
Old 12-08-2012, 08:01 PM
sean's Avatar
sean sean is offline
I have a Central Electronics CRT tester that you can have for free if you wish. I live in Sullivan. I also have a 21-inch 1953 or 1954 Crosley console that is kind of rough but it does work. I bought it with intentions of restoring it but have since bought a very nice 24-inch Westinghouse. Take the Crosley too if you like.
Sean - WØKPX
Old 12-08-2012, 09:03 PM
Learning as I go
PM sent.
