Old 01-06-2013, 06:06 PM
Adam's Avatar
Adam Adam is offline
Zenith porthole 12" console
I finally found one of these. It uses a glass CRT, which tests good (up to 350/1000 on the B&K 420 after leaving it on at 6v for about 5min)
I have the back, but am missing all the knobs. Does anyone have pictures of what the knobs look like? For all I know, I might even have them in one of my boxes of knobs.
The guy I bought it from said someone came to pick it up last week, was all ready to buy it, then said he wanted to fish tank it, and he refused to sell it to him!
Old 01-06-2013, 06:07 PM
josephdaniel's Avatar
Learning as I go
Looks cool would love to have one of those one day.
Old 01-06-2013, 07:07 PM
Try that Mike Koste feller-"Gobs of Knobs" over yonder at AK...
Old 01-06-2013, 10:24 PM
baursam's Avatar
baursam baursam is offline
Adam, have you been able to determine the year and model nbr I might have a couple extras, but would verify against the year/model nbr.
Old 01-07-2013, 12:58 AM
Adam's Avatar
1949
chassis 28F20/21/22
which corresponds to sams # 64-15
which gives the following corresponding model #s: 28T295, 28T960, 28T961, 28T962, 28T963
From the pictures given, I don't have the 28T295 (which is a table model) or the 28T960 (which is a different console)
Anyway, it looks like they all use the same knobs, just different colors.
I can almost make out the knobs well enough from the pictures to go check and see if I have them now.
Old 01-07-2013, 04:40 AM
Adam's Avatar
I think I might have found the smaller knobs, I know some of these Zeniths used these red fine tuning knobs, and I also found these brown ones that are the same size and shape. (The ones with the longer shafts won't fit unless I cut them down) See pic.
Old 01-07-2013, 08:49 AM
John Marinello's Avatar
<-- "Byron"
If that has the original CRT, it'll be a 12KP4, aluminized. Great performer.
Old 01-07-2013, 11:38 PM
baursam's Avatar
I have a 28T925R. Have a couple of extra knobs you are welcome to. I'll have a look tomorrow and let you know. The smaller ones in your photos are not the same but will work in a pinch til the correct ones come along
Old 01-08-2013, 12:03 AM
ha1156w's Avatar
ha1156w ha1156w is offline
Hey! I have that same set! Here are the knobs of the set. Sorry for the lousy quality - old mobile phone....
File Type: jpg Screen shot 2013-01-08 at 12.02.15 AM.jpg (81.5 KB, 39 views)
File Type: jpg Screen shot 2013-01-08 at 12.01.59 AM.jpg (116.8 KB, 49 views)
Old 01-08-2013, 01:51 AM
Adam's Avatar
The CRT is so dusty and dirty I can't read anything off of it. I can see where it says Rauland, which is what I believe Zenith called their picture tubes, so there's a good chance it is the original tube.
Thanks! Let me know what you come up with.
Thanks for the pics. Unfortunately, I don't have those. Can I see the smaller ones? I have lots of those little knobs, I might still have the right ones.
Old 01-08-2013, 07:55 PM
baursam's Avatar
Hi Adam..here are some pics of the channel selector ( one large knob), and the fine tuning knob that sits under the on off switch....I ll post the others shortly
Old 01-08-2013, 08:01 PM
baursam's Avatar
here are a couple of the on off knob, which lays on top of the fine tuning knob, and the four minis, which are for horizontal vertical, fine tuning and brightness...the knob on the previous post that was identified as fine tuning, is actually for contrast.
I have two extra of the mini knobs, and I might have an extra channel selector. I have pm d someone else who was looking for the channel selector, but have not heard back from them, but will give them a few more days.
Old 01-09-2013, 01:09 AM
Adam's Avatar
Thanks for pulling those out. I have a bunch of the smaller ones in a lighter color. Which controls take the knob with the dot, and which the knob with the edge sticking out? ... Actually, the hole on the ones with the edge is too small, so is the hole in the ones with the longer shaft, so only 3 of those fit.
Old 01-09-2013, 07:45 PM
baursam's Avatar
I ll measure them the width of the holes this eve. Its the same knob set that ha1156w posted
Old 01-09-2013, 11:31 PM
baursam's Avatar
The knobs with the dots are under the fold down tray where the horizontal. Vertical. Brightness and fine tuning. The two dotted on the right side look correct. The one on the left looks slightly different. My model, the tabletop, has all dark brown, but I have seen pics of the consoles with white minis instead of brown. Have also seen consoles with brown channel selector, white contrast with a brown on off over top of it, and all white minis under the fold down lid. Its difficult to say but I'd say two of the three little white ones look correct.
