Old 01-31-2013, 05:23 PM
Geist Geist is offline
630 Cap Question
Hi All;
In my 630, the C222B electrolytic cap calls for 50 mf at 50 volts.. I have 47mf at 50 volts, or 100mf at 63 volts, or 100mf at 100 volts.. Which would be best of what I have ?? It is wired in the Cathode circuit of the Vertical Output Tube, accress the Vertical Linerty Control.. R177, and R178.. R178 is the linerty control resistor..
THANK YOU Marty
(I have not been able to copy a partial image of Schematic, so that I could post it here, If anyone else can do so, please add to this posting for clarification..) THANK YOU Marty
Old 01-31-2013, 05:31 PM
oldtvsandtoy oldtvsandtoy is offline
Banned
I would use the 47mf at 50
Originally Posted by Geist View Post
Hi All;
THANK YOU Marty
Old 01-31-2013, 06:11 PM
Dangler's Avatar
Dangler Dangler is offline
47@50 should be fine. They usually have a 20% or greater tolerance.
