Old 02-18-2013, 05:26 PM
mrflex65's Avatar
mrflex65 mrflex65 is offline
Panasonic Tau 27" Widescreen TV Worth Buying?
Hi folks! It's been awhile since I've been on the forum. I might have an opportunity to purchase a 27" Panasonic Tau widescreen TV. I heard these sets are great performers. Is it justifiable to spend the $50 on it? I'd like to use this set in my bedroom. Any thoughts on this?
Regards.
"IPC 610 Class E & J STD-001 Certified"
Old 02-18-2013, 06:29 PM
mrflex65's Avatar
Here's a couple of pics if that helps. I'm wondering if i'm going to be able to manage this lug around this set myself.....
File Type: jpg 3Gd3J33H45N25Gf5K1d2g7d8c986433311085.jpg (25.6 KB, 38 views)
File Type: jpg 3I53M63lf5I55Ka5Jad2g7fbb016afd35151c.jpg (23.1 KB, 23 views)
Old 02-18-2013, 11:17 PM
I really like my Tau, but it is very heavy. It's the 32" non-widescreen version and it's 161 lbs I think. http://shop.panasonic.com/shop/model/CT-32SL13?t=specs
Old 02-18-2013, 11:25 PM
I believe yours would be 100 lbs. Here are the specs: http://shop.panasonic.com/shop/model/CT-27HL14?t=specs
Old 02-19-2013, 07:05 AM
mrflex65's Avatar
Thank you Bandersen for the feedbackI looked all over the net for this model in particular,but couldn't find anything that looked like it.Maybe it's an uncommon one? Any other takers with thoughts on this?
Old 02-19-2013, 07:57 AM
ischmidt ischmidt is offline
Definitely an uncommon set. It was one of the first, last, and only CRT HDTVs made before consumer preference for rear projectors and flatscreens asserted itself.
I have the 34" bigger brother (got it cheap as an ex-floor model circa '03-'04) and it's worked well for me. The two caveats are that it predates 720P being a standard which makes it difficult to use with game consoles (it has 480I/480P/1080I plus NTSC) and the inputs are exclusively component, which is starting to become hard to find on new equipment. But it makes a gorgeous 1080i picture off DirecTV or Blu-ray.
And yeah, it's easily a 2-man job to lift the thing.
Old 02-19-2013, 10:28 AM
mrflex65's Avatar
Sounds like an interesting set! I only wish i knew more about it and the dimensions of it.Can't seem to find any info...
Old 02-19-2013, 10:59 AM
I think I finally found the exact model in your photograph: CT-26WC15 / CT-26WX15.
Here's the owners manual: http://service.us.panasonic.com/OPER.../CT30WX15N.PDF
Old 02-22-2013, 09:45 PM
sssmokin99's Avatar
sssmokin99 sssmokin99 is offline
I have a 20" with DVD player, and my Mom has a 27" with DVD and VHS decks built in. They both have worked flawlessly, the 27 since 2005 and the 20 a bit older. Nice size and great picture, and zero problems. I would say the 27 gets about five hours use per day, and my 20 is used only once in awhile.
**No, I do NOT smoke!**
Marantz-Klipsch-Teac-Akai-Yamaha-Dual-Ortofon-dbx
