Old 02-24-2013, 09:43 AM
Alastair E Alastair E is offline
Non destructive CRT rejuvenation
've been doing some experiments lately on increasing emission of mediocre/poor CRT's.
The set I've done this to is the 'unboostable' trinitron type, a KV1320.
This set was pretty low having poor tracking and focus, just a nasty flat, faded greenish tinted pic was the best I could get.
The idea was given to me by something I've read somewhere of setting up the heaters and drawing a very small current for a number of hours.
I elaborated on this, looking at the effective emissive area of the cathode, (Around 2-2.5mm) a 'good' one should easily pass around 5mA without damage using G1 as the 'anode', for a short period.
This was confirmed using one of those cheapo 6" B/W portables, popular a few years ago, that had remained unused, 4mA was drawn with the set up described below.
The set up was as follows-
A 6.3V heater Transformer and a 12V lighting transformer were used.
The 6.3V supplied the heaters of the CRT to be worked on and also supplied into the 12V winding of the lighting transformer, one rated for 50W that I had around.
The mains connections of the lighting transformer therefore derived around 115V which was fullwave-rectified and smoothed by a 47uF 450V cap.
A Series Current Limiting resistor of 33K was connected to the positive of this 'HT' supply derived across the 47uF cap, which after rectification, smoothing etc, read 145V. I wanted to keep the voltage fairly low so as not to cause any of the usual arcing that destroys the cathode material like often seen with mains derived and some commercial 'boosters'.
A Voltmeter was attached across the resistor to monitor current draw.
The current with the 33K is limited to a little over 4mA (4.4mA ish)
The heaters of the KV1320UB were connected and allowed to run for 10-15 mins to fully heat up.
The negative of the 145V was connected to a croc-clip to connect to the cathodes of the three guns independently. The positive via the 33K was attached to the common G1.
On application of the cathode connection, the initial voltage across the limiter R was 20V.
Very slowly this increased over a period of minutes to 80V odd, then started to go down.
At this point, I disconnected and went on to the next cathode. Same again, although the highest volts was 98V before it started to fall again. Last gun did much the same, with 78V before the volts went down.
The tube was then left with only heaters for 10 mins.
On application of the cathode connection to the first gun 133.5V was found and the current was drawn through that cathode for 1 minute before going on to the next. Again 133.3V or thereabouts was read and again held for 1 minute. The last gun read 134.3V and the current drawn for 1 minute.
This time, the voltage did not fall with any of the cathodes, it remained above 133V.
The tube was then left for another 10 minutes and re-tested by seeing how much volts derived over the current-limiter. All three cathodes drew 133.4-134.3V, which equates to around 4mA.
The tube was then left to cool without heaters or 'HT' applied.
Then tube re-heated (6.3V, no over-volts) and re-tested. The same 133 odd volts was derived straight away indicating an increase in emission, over what the initial reading was.
Now here's the rub! The 3AT2 EHT rectifier has died in this set (O/C Heater) so will not be able to confirm whether theres any improvement or not until I receive a replacement. I ordered one from the USA this morning.
The above was copied from a post I made on 'That Forum' where it gained apparently little interest apart from one reply.
Since then, Ive received the new EHT Rectifier valve, (3AT2) and fitted it earlier on. I tried out the set and cannot quite believe the picture quality.
Where before, it was faded, green tinted and somewhat de-focussed with a little red flaring, it appears transformed, since setting up.
The picture is I would say near what a new CRT would have shown. Bright, Sharp and grey-scale tracking perfectly.
Its a shame that the test is somewhat unequal, as the set also had a new EHT rec due to the original failing O/C heater.
--The set beforehand didnt show any signs however of an EHT rectifier issue like ballooning etc, the rec heater just quit ...
I feel this 'non-destructive' method is worth a try as it places little strain on the cathode's oxide coating and no spark erosion of material which leads to either a very short life or destruction of the cathode entirely, also the important clearance between cathode and G1 is maintained due to no erosion.....
As the above is a Trinitron type tube, the cathodes are very small. (About 1.5mm diameter) as illustrated above, I limited current to 4.5mA
A more usual CRT with its larger cathode surface area I'm estimating by size(About 2.5mm) should take around 8-10mA...
If anyone tries this out--Please let us know how it turns out.....
--This is a thread on a UK based Forum where some guys have tried the idea and have had success--
http://vintagetvandradio.myfreeforum...php?f=5&t=4171
Old 02-24-2013, 06:40 PM
Just thought--There's a mistake in the above for the 110V mains supply in the USA.
We have 240V here, so using the 12V lighting-transformer supplied as I did back-to back with a 6.3V supply, will give you only 75 odd volts after rectification/smoothing....
I would recommend use a straight isolation transformer to give 110-120V before rectification to supply the 'HT' supply for the process above...
BTW,--Sorry while trying to correct a spelling mistake, this thread got posted twice....
Old 02-24-2013, 06:48 PM
Kewl ! Thanks for posting...
Old 02-25-2013, 11:49 AM
Reece's Avatar
Reece Reece is offline
Very interesting and useful and rigorously carried out experiment. Thank you for the information. BTW, our voltage here is around 120 volts most places.
Reece
Old 02-25-2013, 01:51 PM
I want to try this.
I was wondering just how closely this procedure is to the Beltron Rejuvenator?
It seems to work in a similar fashion except you have to turn the heater voltage up to 10 volts and it doesn't take 10 minutes, I'm not sure if it causes arcing or not.
Old 02-25-2013, 02:27 PM
I think it's also similar to the "auto-restore" function in the Sencore CR70. That uses an elevated filament voltage and ramps voltages to increase the emission current in a controlled manner. The CR70 rejuvination function does blast the cathode and cause an arc though.
Old 02-25-2013, 06:44 PM
In my ill gotten youth working in a TV shop, I had charge of disposing of the old sets and CRT's...
I would take them out the back and lop the guns of the CRT's off with a hammer.--Not safe, but strangely satisfying--for a teenager!
Thinking back, wish I had saved some of the more rare CRT's and sets now.....
I used to dissect the various guns from the tubes, and noticed the Sony types always had Really Tiny cathodes. --Ive seen bigger pinheads!
They are/were only around 1-1.5mm in diameter, while the other sets delta gun tubes like A56-120X, (A development of Mullard under-licence from RCA--guess there is a 560xxx22 equivalent over in USA), and Mono tubes had much more robust looking cathodes--About 2.5mm diameter for most of them, and looked 'solid' in comparison, to the feeble tiny Sony CRT parts.
Always reckoned that this was the cause of the 'unboostability' we found in UK using the old 'Bulb-Bopper'--Even the B-K wouldn't do them--Always ended in disaster.
(A 15W pygmy bulb wired in series with cathode, grid and 240V mains. It also had some switches and a 6.5V-8V transformer)
The tiny Sony cathodes were literally torn apart by the heavy arcing and currents the 15W bulb allowed to pass--Lit this is around 60mA, More with a cold bulb. No wonder all the sparking occured!
I'm guessing the same old process of slow ageing over the years must be causing the sony tubes to go low, just like them all, no different really apart from the size, so tried the above as an alternative--Nothing to lose on a stuffed CRT!
I notice probably every CRT booster has an increase heater option while boosting, maybe with some very low CRT's this is essential to get things started...
Just go in small stages till you get some current flowing and make sure there's no arcing going on!
Old 02-26-2013, 04:23 PM
Firebird's Avatar
Firebird Firebird is offline
Can you show pictures so i can understand the whole process or email them to me. Thanks
Old 02-26-2013, 06:53 PM
Not quite sure what you need....
Ive no pictures of what I did! The description of the process and parts is pretty simple, and has been duplicated by others......
Old 02-27-2013, 08:01 AM
DavGoodlin's Avatar
Motorola Minion
A sony trinitron socket was usually not supplied with most CRT testers.
Maybe because it's too easy to "strip" the cathodes using the usual clean-rejuvenate functions.
I did try making an adapter for my Heathkit CRT tester, which had a "clean" function using 120 volts DC similar to your method and it was current-limited using 120 volt pygmy lamps (3 watt, S6 bulb, candelabra base).
The method to prevent arcing was to apply this voltage to a "cold cathode" then gradually increase the filament volts until a soft glow from the lamps and the meter climbed to 3 (scaled 1-10, not corresponding to any current value) then you did this for 15 seconds or so. I have noticed that keeping it "on" longer and the meter started to fall again. I sucessfully restored a few Sony and Panasonic CRTs this way.
Old 02-28-2013, 08:58 PM
Firebird's Avatar
I do not have any experience working in a shop so pictures would help with some of the details. Thanks.
Old 03-10-2013, 08:40 AM
I'm sorry, I have no pictures.
Old 03-11-2013, 10:03 PM
Firebird's Avatar
Thanks.
Old 03-20-2013, 10:31 AM
cbenham's Avatar
cbenham cbenham is offline
Would it be possible to draw a schematic of the system you built with voltages at critical points shown and post it?
I think that would solve the confusion.
Thanks...
Old 04-23-2013, 06:51 PM
Old TVs are better!
I use a Beltron, and found that if that doesn't do the job, nothing else will. I've in the past have tried several different CRT rejuvanators, and the Beltron does what it's suspose to do. I assume the procedure above is similar to what the Beltron does.
