Old 02-25-2013, 12:35 AM
charokeeroad's Avatar
charokeeroad charokeeroad is offline
John Q
Zenith Roundie
Picked up this Zenith Roundie this evening. Thanks to DaveWM I was able to determine that the CRT was good. My tester really let me down on this one. It showed no emissions on any gun. I called Dave and he guided me through a simple test that in this case proved the CRT was good. Thanks Dave.
File Type: jpg 3Ea3Gd3J65G85Ee5M8d2hf1bf6304376b124d.jpg (37.3 KB, 63 views)
File Type: jpg 3G83Ka3Fa5N65L45Kdd2hab4c1e8c590b18d0.jpg (18.4 KB, 78 views)
Old 02-25-2013, 09:21 AM
That's a nice looker, what chassis does it have? It looks like a late 1964 model. Great score!
Old 02-25-2013, 09:49 AM
WISCOJIM WISCOJIM is offline
John, could you or Dave share the details of this test for everyone's benefit? It could prevent other good CRTs from getting tossed.
Old 02-25-2013, 09:59 AM
His CRT tester was showing no emissions. The set had been in sevice, but he did not have a test signal to see the actual picture. It did have a raster.
I just told John to turn the screens down and then one by one turn them up, they each produced a bright raster. Not very scientific, but if your tester is showing zero emissions then I presume its the tester under the circumstances.
Old 02-25-2013, 10:05 AM
Thanks for the reply Dave. In this case the tube was known to have a picture, thus had to have some emissions.
I was thinking perhaps you had a test for a CRT not in a working set.
Old 02-25-2013, 10:11 AM
right. I figured there had to be an issue with the tester, so the next best thing was did each color make a good raster, with out a weak color (generally red).
I have done this before where I was caught without a CRT tester AND the owner had already been turning it on "to test it". Like I said its not very scientific, and not really checking for cut off, but in a pinch...
Of course its better to not turn on a set if its been idle, like the guy with the moto wants desperately to do.
Old 02-25-2013, 10:14 AM
marty59's Avatar
marty59 marty59 is offline
Hhmmm.....I gonna' make a fun guess here and say it's either a 25LC30 or an early version 24MC32. The 21FBP22 dates it a little bit but I could be wrong!
Old 02-25-2013, 10:21 AM
Yeah, that looks like trouble in the making...
If the guy with that Motorola is so worried about getting top dollar, he should contact someone familiar with 15GP22 CRTs and have them go to Utah and check it out. Then share those results here and with the ETF crowd, and auction it off.
Old 02-25-2013, 11:57 AM
Are you guys talking about the guy with the '54 Westinghouse? Or, did I miss a Moto somewhere around here....
Old 02-25-2013, 12:02 PM
Sorry, Mark. You are correct, the Westinghouse.
Old 02-25-2013, 01:36 PM
No apology needed, I just thought there was something I missed!
Old 02-25-2013, 02:46 PM
John Q
Dave's right, My tester didn't work at that moment. I think it didn't make good connection on the appropriate pins. I couldn't get my meter to come up to the cut off line. On my tester, a B&K 465, I first set the heater voltage, in this case 6.3 volts. Then I set the G1 to 40. Next I set the function switch to cut off and use the G2 control to set the meter at the cut off line. Lastly I switch the function switch to emission and see what the meter reads. I couldn't get any of that to work last night so I assumed the CRT was not emitting although it was clear that the filaments were working in all three guns. Thinking what harm could there be if the CRT was dead anyway so I turned the set on and the set had a great raster!
That's when I called Dave and he walked me through the test he described above.
When I got the set home and set up the tester again everything worked fine. I got an emissions reading of 880 on the red gun, 820 on the green gun and 820 on the blue gun. Since it had already been turned on yesterday with no ill effects I turned it on again this morning and here are some screen shots.
Old 02-25-2013, 02:56 PM
Zenith26kc20's Avatar
virtually the same set I have. Do you have the legs?
A real sweetie of a set when working right and a workhorse to boot!
Old 02-25-2013, 03:42 PM
John Q
no legs on this one
Old 02-25-2013, 04:20 PM
you are pretty close to have it working well. check that contrast adj, if it does not very much, then you prob have an open cap in of the cans, the 200uf IIRC.
A quick test will be to tack in a 200uf + to the center of the contrast pot, neg to ground. just use some jumpers for a quick check. the blurryness is a result of the cateract.
