Old 03-09-2013, 08:48 AM
Magnavox300's Avatar
..better in black & white
Multi Can Capacitor question
I want to use a multi can capacitor, 40uf,40uf,20uf, and was wondering if I can hook up all three leads at the can, and make it one 100uf cap?
I know I can use a single 100uf cap, but need to use a can type, so is that okay to do?
Magnavox300
Old 03-09-2013, 08:57 AM
davet753's Avatar
davet753 davet753 is offline
David Thomas
I have done that with filter capacitors. Just last week, I needed to replace a 100uf/40uf filter capacitor. The closest thing I had was a three section cap 50uf, 50uf, 50uf. I tied the two 50uf sections together and installed it. The new 50uf was a little more than the 40uf cap, but in a filter circuit it's close enough.
Is your 40,40,20 a power supply filter?
Old 03-09-2013, 09:00 AM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Yes, you can always hook capacitors up in parallel, as long at the voltage rating of each section of the can is greater than the actual working voltage they will see in the circuit. They don't need to be the same rating, but as long as each one is rated for a higher voltage than what they'll see, you'll be fine.
Old 03-09-2013, 12:23 PM
Thanks, I thought so, just making sure...
Yes, it is for a PS.
Thanks again!
Magnavox300
