Old 03-17-2013, 04:24 PM
josephdaniel's Avatar
Learning as I go
My new predicta
I just got home and as soon as I got out of the car I gave it a much more detailed look and I saw modern capacitors underneath the set so I pulled out the chassis and someone replaced all if the caps underneath but not on the board!!
On the pc board everything was original and there were two black beauties that were cracked. After all if this I decided since most if the components had been replaced it would be reasonably safe to power it up I got good sound but it was a little weak and no raster I suspect a cold joint in a tube socket since I saw a raster when it was in the mall but I didn'ta leave it on long enough to warm up.
Lebe dein leben für dich selbst
**Searching for any all tube or hybrid or color portable sets would consider some early solid state color too**
Old 03-17-2013, 09:44 PM
mpatoray's Avatar
mpatoray mpatoray is offline
Congrats on the new Predicta!
Check out Bob's series of videos on the Predicta Holiday. A LOT of good tips in there and how to deal with the early PCB's and the cuplates.
http://www.youtube.com/playlist?list...2y62xYCp5PgZx_
Old 03-17-2013, 09:49 PM
Dude111 Dude111 is offline
Analogue is Awesome
Good for you my friend
Old 03-18-2013, 02:56 AM
StellarTV's Avatar
StellarTV StellarTV is offline
Wow, not only a great price but so much work already done for you!!
Makes me wonder where the set came from... it might be interesting if you get a chance to talk to the dealer and ask them the backstory.
Old 03-18-2013, 07:42 AM
Learning as I go
I would like to know its story and why the person stopped working on it. Hopefully they dident discover that some unobtainun part wasn't fried like the flyback or CRT
Old 03-18-2013, 10:52 AM
Looks like it has the original thermistor and filament dropping power resistor. Often one or both of those are bad.
Old 03-18-2013, 10:56 AM
Learning as I go
The thermisistor is good but I don't know what the dropping resistor shops measure at on my ohm meter?
Old 03-18-2013, 11:00 AM
Learning as I go
Also what should the voltage readings be on the pins of the CRT?
Old 03-18-2013, 12:38 PM
You can download the Sams service info for free here: http://www.earlytelevision.org/tv_sc...s_postwar.html
Old 03-18-2013, 12:44 PM
Learning as I go
Thanks! That will be a lot of help when I get into the set more.
So do you guys think when I pull the PCB I should rebuld all of the networks that seem to go bad frequently and all of the resistors as a precaution?
Old 03-18-2013, 02:22 PM
StellarTV's Avatar
I wouldn't rebuild the networks unless you really want the practice. If you'd like to tackle one, which in my opinion is the worst offender and also the simplest to build, tackle the vertical integrator, which is the short 4 pin network next to the vertical output.
Old 03-18-2013, 02:58 PM
Geist Geist is offline
Hi All;
Joseph, Bob Andersen, has in His Predicta Video's, about How He rebuilt His Integraters.. Check it out And then decide..
THANK YOU Marty
Old 03-18-2013, 03:05 PM
Learning as I go
Originally Posted by Geist View Post
Hi All;
THANK YOU Marty
I will. I was just thinking that since the boards are so hard to remove in these that I would just do them all while it was out since they seem very failure prone. Has anyone actually opened up one of these networks to see what exactly is inside?
Old 03-18-2013, 03:36 PM
Yes, I did at some point in the videos. Some are just encapsulated discrete components (carbon comp resistors, ceramic caps, etc). Other networks (vertical integrator) are made from carbon and metal deposited on a ceramic substrate.
Here's my restoration thread in case you haven't read it yet:
http://www.videokarma.org/showthread.php?t=255328
Old 03-18-2013, 05:02 PM
Learning as I go
If the video output tube (6aw8a) is gassy or dead would that cause the screen to be completely dark I just looked at this tube with the set on and it is very purple inside when on so is the horizontal output tube.
I have determined there is HV but I don't have a probe to measure the exact voltage but I can get a 1/2 centimeter spark to the housing of the flyback transformer.
