Old 03-20-2013, 02:04 AM
Tubejunke's Avatar
Horizontal efficiency coil concerns
I may need a horizontal "efficiency" coil for my 1964 Zenith 5111. When I found the set there was no HV and the H. Oscillator tube plate was glowing red. I replaced the voltage regulator tube and the HV rectifier and had a raster. I just happened to notice on a visual inspection that this coil's winding end moved when I pushed lightly on it with my finger. I think that it should be rigid in order to be accurate, but I could be wrong as I don't know whether the mounting portion is just broken and would not effect the circuit, or if the actual inductor winding portion is loose.
I fear the latter as it seems springy to the touch. That could be the wiring. At any rate, it might be best to replace this if I need to and can find one. I know that all issues horizontal are critical in these old color sets which I am by far not an expert on. Any advice and/or help here would be greatly appreciated. Thanks in advance!
Old 03-20-2013, 06:42 AM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
My 1965 Zenith roundie had the same symptoms, no HV and horizontal output glowing cherry red. The horizontal efficiency coil had a broken plastic coil form. After replacing it all was well. If that coil is in doubt it is best to change it. It is not worth risking damage to the flyback.
Old 03-20-2013, 10:40 AM
Yes, that coil is absolutely critical, as it's used to tune for the sharply defined 'dip' in HO tube cathode current. When the coil form breaks and the windings go springy, that resonant point is lost.
Old 03-22-2013, 08:40 AM
Tubejunke's Avatar
Wow! Great info folks and my suspicions were right. Glad I didn't get stubborn and try to put a lot of play time on the set. Of course I never would have powered it for more than a minute with a red H.O plate, but that went away when I changed out those tubes.
Enough of the story and on to more important things. Where in the world am I going to find a good coil? If anyone has an extra I would gladly buy it. and for the record I just parted a pristine Space Command (black and white) set. So if there are any early remote control fans out there wanting to do some trading, perhaps we could do that. I really want to get my set going. I also need a nice control cover door. Mine is there, but a bit tattered.
Old 03-22-2013, 08:54 AM
I have a parts chassis that may have the coil still, it may also be burned up if it's there. I'll check and if it's good, it's yours.
Old 03-24-2013, 12:55 AM
Tubejunke's Avatar
Hey thanks! Evidently these things aren't made all that well. You may have to be real tender yanking that one. Do me favor (and yourself) and just snip the wires. Then I can just re-connect to those without even heating the coil. I'll keep my fingers crossed. Thanks again!
Old 03-24-2013, 11:52 AM
What happens is, the inside tube of the coil form crystalizes from heat and lets go. There's a couple of (blue) coils on the convergence board that run pretty hot and have the same problem. If they haven't let go yet they will eventually.
As a proactive/ preemptive measure, it seems like it oughta be possible to bind the outer frame to prevent separation even when the inside tube crystalizes.
Maybe a few turns wound front-to-back of something like dental floss, tack glued in place(?).
I've never done it, but has anybody ever adapted the RCA type eff.coil to work in a Zenith?
Old 03-24-2013, 02:37 PM
Tubejunke's Avatar
You could probably dip the whole thing in some type of hard epoxy in order to preserve it and prevent the breakage. As far as adapting the RCA type I would imagine that if the inductor windings and the (what I assume to be) iron core adjustment meet the same specs, then the part would work. It probably wouldn't mount up the same though. I don't want to go that route. Just hoping for a decent stock replacement. Hopefully Zenithfan1's plan will come through for me.
Old 04-11-2013, 02:28 PM
I was able to get to that chassis a few days ago and I'm sorry to say, it's one of the many fried parts in the Horiz. out section. I hope you find one soon.
Old 04-11-2013, 02:38 PM
Tubejunke's Avatar
OK, thanks a ton for looking! I know these sets are really popular, and I know about the critical nature of strong horizontal/H.V. sections, so there must be some outlet for parts. I guess the norm is caps and resistors which we buy from distributors. I wonder where I can find this coil??
Old 04-11-2013, 06:51 PM
Tim's Avatar
Tim Tim is offline
It would help if you could post the Zenith part number and any subs that Sams recommends.
Tim
Old 04-11-2013, 11:10 PM
Tubejunke's Avatar
Excellent idea Tim. I might just be able to do that. Should be listed in the Sam's parts section. Guess I took it for granted that since so many people are getting into early color sets that a Zenith coil would be well known. I found out that others have had them break and it caused problems.
I have a mint condition 50s Zenith remote control setup for trade in some parts for this set. I need this coil, a decorative control door, and a tuner knob (outer).
Old 05-16-2013, 01:30 AM
Tubejunke's Avatar
Sam's lists this inductor as part # S-62016. I'm not having much luck finding one, but with what seems to be confirmed here there is no use in proceeding with restoration work without one. As many of these beloved "roundies" as are now the rage, I would think that one will pop up eventually or really by now. I guess those that have them are using them. I am going to have to luck out and find someone who has junked out a basket case.
At this point I am regretting all of these sets that I myself junked out back in the 80s when you could pick them up for a song working fine.
Old 05-16-2013, 09:25 AM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
The handy-dandy guide I got from Bryan a few months back lists an equivalent by Thordarson, # WC-39. eBay is your best resource for these, IMHO
Old 05-17-2013, 11:37 PM
wkand's Avatar
wkand wkand is offline
coil
Here's what a search for a wc39 yielded. Cut and paste into your browser, good luck!
http://www.remelectronics.com/Search...cturerAbbr=THO
