Old 03-31-2013, 01:09 PM
chipper chipper is offline
6.3v FILAMENT VOLTAGE
I have a 6.3 v filament transformer for the crt on my philco set , but even at 117v pri power ,to the transformer, the sec voltage is between 7-8v, to the tube. Should I wire a resistor or pot to control the voltage and keep it around 6.3v ?
Old 03-31-2013, 02:26 PM
Reece's Avatar
Reece Reece is offline
Your transformer is OK and working normally. When you have the filament load on it, it should drop to around the proper voltage.
Reece
