Old 05-22-2013, 11:51 PM
Toshiba's Avatar
Toshiba Toshiba is offline
C Transformers??
Hello! I just found an old Philips organ and took it apart for tubes. Then I found some small transformers that appears to be C Transformers....?
Can anyone tell me what these are? Can I use them to make stereo tube amplifier?
Thank you!
Old 05-23-2013, 11:03 AM
bob91343 bob91343 is offline
Maybe, but just looking won't tell you much. See if you can trace the circuit. After all, an organ is just an oscillator and an amplifier, so that's the kind of parts you will find.
Do you have a model number? Obviously there is at least an output transformer. High fidelity, well that depends on your definition.
