Old 07-06-2013, 01:39 PM
wiseguy wiseguy is offline
Old 07-07-2013, 04:49 PM
Nice to see that set on its way to good operation.
Old 07-07-2013, 09:55 PM
Zenith6S321's Avatar
Zenith6S321 Zenith6S321 is offline
Cool, looks like you are making good progress. Glad to see your CRT is good! When I get some time I'm going to try using the Sencore VA62 alignment procedure to try to get rid of my vertical white line. Good luck with yours.
Dave
Old 07-08-2013, 02:39 PM
miniman82's Avatar
First Light: 1952-2011
Poor sync can still point to horizontal issues, make sure you have all the correct voltages. I just use the procedure in Sams, it's a good one.
Evolution...
Old 07-08-2013, 03:49 PM
Old 07-08-2013, 06:24 PM
miniman82's Avatar
Originally Posted by wiseguy View Post
I am Curious what type, or part number everyone has used for the ALL 250uh peaking coils, since there are many and I was able to get what was in the sams Meissner brand, "19-3250"
I didn't worry about originality with those, I just shopped at Digikey:
From phase detector to reactance tube grid: M10101-ND (1 piece)
Matrix output to CRT: M10093-ND (3 pieces)
Y-line, near delay line: M10082-ND (1 piece)
R-Y demod/amp: M10083-ND (2 pieces)
Q demod: M10098-ND (1 piece) and M10127-ND (1 piece)
Y-line near 2nd video tube, and matrix power input: M10106-ND (5 pieces)
^ That's from my CT-100 resto, but the 2 chassis are similar enough. I put the same coils in both my CT-100 and 21-CT-55, the colors on the screen were very nice. No one will know you didn't get correct pi wound coils, it dosn't appear to make any difference.
Evolution...
Old 07-20-2013, 03:42 PM
Old 07-20-2013, 06:22 PM
Old 07-20-2013, 06:54 PM
But you're SO close ! I wish I had, 1) a '50s color TV, & 2) the technical knowledge/ability to work on it & NOT kill it..
Old 07-21-2013, 01:34 PM
Old 07-21-2013, 01:35 PM
Well here Sandy, you can take this one on.
Old 07-21-2013, 02:01 PM
Danke Schoen, but do the words/phrase "Bull in a China Shop" mean anything to you ?!?
Old 07-21-2013, 05:57 PM
Old 07-21-2013, 06:50 PM
Nice progress! The current through the fuse in my CTC2B is also right around 206-208. I think I finally have a good IF alignment, but I still have a little more work to do on the color alignment.
Dave
Old 07-21-2013, 07:01 PM
