Old 07-12-2013, 05:35 AM
John James's Avatar
John James John James is offline
Black screen! Oh no!
I've got a 40 in. Polaroid LCD TV. when I try to power it up I get a black screen. The audio is fine. When it worked right, the word "POLARIOD" would show for a couple of seconds and then it would go to the picture on whatever channel I was on. Now, sometimes the word POLARIOD just barely flashes and then the screen goes black. Does anyone have any idea what may be wrong?
Thanks for your time,
"It's never loud enough"
C 26, MC 250, MC2505, TEAC T-R600, TECHNICS SL-P500, SONY TC-WE425, CERWIN VEGA R-26, KLIPSCH KG-3.5
Old 07-12-2013, 08:11 AM
rlovison rlovison is offline
Originally Posted by John James View Post
I've got a 46 in. Polaroid LCD TV. when I try to power it up I get a black screen. The audio is fine. When it worked right, the word "POLARIOD" would show for a couple of seconds and then it would go to the picture on whatever channel I was on. Now, sometimes the word POLARIOD just barely flashes and then the screen goes black. Does anyone have any idea what may be wrong?
I have a Toshiba 32HLC56 that did the same thing. It's called "2 seconds to black." Info can be found here:
http://www.badcaps.net/forum/showthread.php?t=10419
My problem ended up being a bad transformer on the inverter board. I could have replaced the transformer but instead I found a used inverter board on eB*y for the price of one brand new transformer so I just swapped boards. Your problem could be as simple as mine or something more involved. Maybe someone with your make and model can give you more info.
Old 07-12-2013, 08:33 AM
Bill R Bill R is offline
The floursent back lights are not coming on. Usually a problem on the inverter board. It should be the board the tubes connect to. There is a transformer for each tube I think. Dont hold me to it though. Someone on here is likely an LCD repair expert and may be able to help. The Polaroid sets did have some capacitor problems I have heard as well. So power to the inverter is also suspect.
Old 07-12-2013, 08:55 AM
John James's Avatar
Thanks. I'll start checking those things that I can and hope its something simple as I have no background in this kind of thing.
Old 07-12-2013, 09:47 AM
Zenith26kc20's Avatar
Capacitors fail rapidly on these sets. If it is one with the removable hatch in the back, it will reveal the module easier than most.
If caps don't repair it, keep in mind some of the Polaroid sets are devils to use, even with the correct remotes!
I have to say, I don't give them as much effort as other LCD sets as I find their picture a bit poorer than most.
Old 07-12-2013, 11:02 AM
John James's Avatar
I have been using this in my garage so picture quality is not of prime importance. It was working fine and then....
Thanks for your time though.
Old 07-13-2013, 09:49 AM
John James's Avatar
Good morning,
I tried the flashlight trick and there is a picture in there! Now how do I get it out? I'm assuming there is a problem with florescent lights?
Thanks,
Old 07-13-2013, 11:09 AM
Good morning,
Thanks,
John,
The CCFL tubes might be OK though something on the inverter board might have failed. What model Polaroid is it?
Old 07-13-2013, 12:36 PM
John James's Avatar
Originally Posted by rlovison View Post
John,
POLAROID 40" HD Widescreen TLA-04011C
Thanks.
Old 07-13-2013, 03:50 PM
Here's an inverter board for a TLA-04011C set. Not sure if it's exactly what you have as the model number seems to be used on many sets having different size screens.
http://www.ebay.com/itm/POLAROID-TLA...-/190696895817
I'm not telling you to purchase it but now you know what to look for when you remove the cover from your set. Of course, unplug the thing first.
If you discover what model transformers are on the board (big rectangular things with coils of wire) you can than test them using a voltmeter in resistance mode. Hopefully someone on this forum has experience with your model television that can help you out.
Old 07-13-2013, 08:18 PM
John James's Avatar
Thanks for the info and link. I've got to get the set off the wall so I can open it up. (Time for a call to my neighbors!) I'll keep in touch and let you know what I see.
Thanks,
Old 07-27-2013, 10:40 AM
John James's Avatar
I finally got the set off the wall and opened it up. It is entirely possible that this connector (see picture, at top, white plug) was off when I took the back off. I did not have to unplug it like I had to do to all the others. If that was unplugged, that would explain why I had no back lights wouldn't it?
Old 07-28-2013, 09:50 AM
John James's Avatar
Update. I plugged the white connector back in and powered up the TV. The back lights came on for a second and went back out. When they were going out, I heard a bacon frying sound that came from (I think) one of the black rectangular things at the top right of this picture. At the same time a little red light located to the left in the picture came on. Does this mean I have to replace this whole board, or just the rectangular what-chama-call it? BTW, I know next to nothing about soldering.
Thanks,
Old 07-28-2013, 10:10 AM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
Those are the HV transformers for the inverter. One is probably going tits up.
Old 07-28-2013, 10:11 AM
John James's Avatar
Does that mean replacing the board?
