Old 07-25-2013, 07:45 AM
DavidGoncalv's Avatar
DavidGoncalv DavidGoncalv is offline
16TP4 - gun alignment
See http://i.imgur.com/TQaP0Qq.jpg
This tube seems to be fairly similar to the 16KP4 - no aluminization, almost the same specs. Looking at the gun assembly, it whole of it is tilted in the base by some amount. I thought that ion-trapping was done in only part of the gun assembly, not with the whole - but what the heck to I know.
Does it look right?
Old 07-25-2013, 08:34 AM
Zenith26kc20's Avatar
Looks like sloppy alignment at the factory. I have seen the "bent guns" you are talking about. Does this tube work?
Old 07-25-2013, 12:16 PM
I've seen tubes like that before, pretty sure it's for Ion trapping.
Old 07-25-2013, 06:12 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
I have a 17RP4 that arrived here looking like that. I thought it was dammaged in shipping. I installed it, set the ion trap, GREAT PICTURE...
Turns out some guns were made that way. Unless it tests bad, i wouldnt worry about it
SR
Old 07-25-2013, 09:48 PM
its ok , they where made that way .
Old 07-25-2013, 10:23 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
Yes, the gun was intentionally installed that way. It needs an ion trap or "beam bender" to function properly.
The ion trap is used to pull the electron beam back on-axis, while the heavier ions shoot harmlessly into the inside walls of the tube.
Old 07-25-2013, 10:27 PM
Mal Fuller Mal Fuller is offline
Ion traps were also known as beam benders, for what are now obvious reasons.
