Old 08-05-2013, 03:57 PM
technicolor's Avatar
technicolor technicolor is offline
go big or go home
64 rca weird black caps
doesn't look like an electrolytic but is definitely not your standard orange drop either
opinions please, no polarity markings other than the ring on one side:
it's a .047
Old 08-05-2013, 04:34 PM
Can you find a value marking (or a value in the schematic)? If a few tenths of a microfarad, probably a foil cap - the band would indicate the outer foil.
Old 08-05-2013, 04:42 PM
go big or go home
Hey thanks, otn, i got the value, just want to make sure it's not an electrolyte.
Old 08-06-2013, 07:45 AM
WCF720's Avatar
WCF720 WCF720 is offline
It's a film part, banded end would be the the foil/"more grounded" side. Treat it like an orange-drop with a band. Replace it with a Nichicon or Panasonic film part of the correct capacity/voltage and your good to go! I'd suggest replacing any part that looks like that, or the'bumble bee' capacitors, and certainly any and all wax parts if you find. I have found the early orange-drop, and burgundy-drop looking parts to be leaky, especially in the convergence area, and sweep circuits.
