Old 08-28-2013, 12:41 PM
jg6364 jg6364 is offline
1978 Sylvania console problems
I have had this set for several years. About a year ago the HV tripler was replaced. Just recently I was trying to play it and the picture is scrambled. The audio is great and if you turn the fine tuning ring the picture will go completely black just when you think it is going to clear up. I'm attaching several pictures and a video What should I be looking for? I pulled a lot of the transistors and cleaned the connections just in case that was the problem but no luck.
video http://youtu.be/DWW_RvhQrag
Old 08-28-2013, 02:08 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
Looks a lot like agc overload. Try backing off the agc control slightly if it has one.
Old 08-28-2013, 04:25 PM
I didn't see any adjustment but there are two AGC det ic's in the deflector module.
Old 08-28-2013, 06:12 PM
sampson159's Avatar
sampson159
i have the same chassis set.agc ic s were a fairly common issue with this chassis.i may have an extra module for this.not sure but the 19 inch chassis had the same ic s.turn off the afc and perma tint.try to fine tune it.you can also try another channel if your using a converter box.pretty simple,straight forward sets.no frills,just simple chassis with a really fine crt.love these sets and worked on many of them.
Old 08-28-2013, 07:45 PM
I would love to get this set back working. It always had a great picture until this. Let me know if you have the modules or the agc IC . I tried the other things you suggested, nothing worked. If it's the module that I'm thinking it is, the one with the agc det ic then the module number would be 32-41658-3. That IC is IC400 in the diagram and the number is 15-43312-1. I have no idea how to check those. I don't have a schematic or service manual for this set. Any help at all is really appreciated.
Jeff
Old 08-28-2013, 08:12 PM
The set has the look of outside interference to it.
Try a different source if you havent.
Also try reseating the 3 modules & check the IF cable.
Do a little tapping around.
If you post the model & chassis I will pull the manual
& see what its got for AGC, to long ago to remember.
Old 08-28-2013, 08:15 PM
OOPS just noticed E45-01. I will look it up tomorrow.
Old 08-28-2013, 08:30 PM
Thanks so much , glad you saw the chassis number LOL. The model number is CL7237P-1
Jeff
Old 08-29-2013, 08:41 AM
I cleaned the connections on the modules and cleaned the tuner. I pulled up some color bars and switched between channels 2 thru 6 no change.
Old 08-29-2013, 08:56 AM
sampson159's Avatar
sampson159
looks more like a horizontal oscillator problem.the first module is known for cold solder joints around the if ground plate.its in the center of the module.the 3rd module is horizontal/vertical.also been known to have cold joints.is this the original black matrix crt?they make a pretty picture when they are good.didnt last long,usually about 3-4 years but still the best picture.a flat chassis zenith with this crt would be the ultimate set!good luck with this set.
Old 08-29-2013, 09:23 AM
Yes it's the original CRT. It's dated February 1978, same as the cabinet. I will check the 1st module again. I've checked the third module, could not find any bad solder joints. I even checked the electrolytic caps. They all checked between 5 to 10% tolerance.
Old 08-29-2013, 10:33 AM
I found a few cracked solder joints on the shielding but that was it. I fixed those and cleaned another connection on the module pins. At times it plays a little better but still not fixed. Thanks for all the info on this type of set. I really appreciate it.
The top shielding was removed for the picture below.
Old 08-29-2013, 10:41 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Keep on trucking, I consider this one a keeper.
The IC in the pic with the shielding removed, it doesn't look to be soldered in, have you re-seated it?
Old 08-29-2013, 11:34 AM
holmesuser01's Avatar
I made a fair amount of money on these Sylvanias. I did service for a rent-to-own business that had around 100 of them, and about 100 19" version sets.
NEVER had a bad CRT in any of them. Fine sets, all around.
Kept a stock of knobs for them. Rental customers were good at returning TV's with no knobs.
Those sockets under the IC's and transistors were not terribly dependable. When I found bad sockets, I'd remove the socket and hard-solder the IC/transistor in place on the chassis.
Try cleaning the pins on the board connectors, and look for cracks around the connectors on the modules.
Old 08-29-2013, 11:41 AM
OK got the Sams.
IC 400 & Q202 are the AGC semis. Also some eletrolytics
C420, 215, 216, & 211. Also C130 1mf probably mounted
on tuner at AGC terminal.
There is NO AGC adjust at all.
Normal range at IF board pins are
TA22 4.43- 11.31VDC
TA21 4.62- 9.56VDC
Tough to call this one could be AGC or IF dont think video.
Hard to tell not being there.........
PM sent
