Old 09-01-2013, 07:52 AM
consoleguy67 consoleguy67 is offline
60s Throwback
AGC on Zenith 24NC31Z
I have a 1967 Zenith color set with chassis 24NC31Z. Every once in a while, the contrast seems to flicker darker and lighter. I've adjusted the AGC control down. Are there some tubes in that particular circuit that I should check?
Thanks,
Frank
Old 09-01-2013, 08:38 AM
if the agc is super critical in adjustment I would check a 5uf cap somewhere in that circuit. if the AGC react normally to adjustment then check the electrolytic in the contrast circuit, part of the video out IIRC.
Old 09-01-2013, 09:55 AM
6BA11 is AGC tube. Best test is light tapping of tubes
while watching picture. If you find a sensitive spot
try cleaning socket first. Changes in contrast can be
anywhere from the tuner through the IF's, video amps & AGC
you really gotta see it to tell.
I have the manual out if you have any more questions.
Old 09-01-2013, 12:24 PM
60s Throwback
Thanks. I'll check it out and let you know what I find.
Frank.
