Old 10-06-2013, 10:41 PM
Magnavox300's Avatar
..better in black & white
Why is the CRT taking longer to light up?
I have been enjoying my 1960 Magnavox set for a while now,
but recently, when I turn it on, the CRT takes a few minutes, sometimes longer to light up...the sound is there right away though.
Any simple fix?
Old 10-06-2013, 10:58 PM
bob91343 bob91343 is offline
Is the CRT taking longer, or do you mean the display takes a long time? If the heater isn't drawing enough current to get its temperature up, that's one thing. If you are referring to the delay before a picture appears, that's entirely different.
Old 10-06-2013, 11:43 PM
StellarTV's Avatar
StellarTV StellarTV is offline
Could be a number of things without getting some test readings, but first thing that comes to mind would be a weakening CRT.
When it lights up, is it sudden, or does it slowly come up over the now increasingly gradual period of time?
EDIT: Basically echoing Bob's input
Old 10-07-2013, 12:11 AM
What I mean is the display is taking a longer time than normal.
No light at all on the screen... then it pops on.
It is sudden, not gradual.
Old 10-07-2013, 12:46 AM
There are two things that can cause that, either the CRT is reaching normal emission level slower(which is either the CRT going bad or the electron gun drive circuits), or the HV supply is taking longer to come up.
Old 10-07-2013, 08:58 AM
If you have a hv probe, you could easily test the hv as the set comes on....
We had a similar looking set when I was a kid, The picture got really light in contrast, like the one you posted.... Dad changed the picture tube, no fix, changed tubes, nothing, then after a while we took it apart, made a storage cabinet out of it, I was not old enough to know what to do to fix it at that time. Today of course I would go to the video amplifier area and get cracking...
That set has a vertical chassis with a hole around the picture tube, little black box lower right I think for the flyback.... With a overhead pull light chain attached to the cover....
Old 10-07-2013, 10:13 AM
kx250rider's Avatar
REAL TVs have TUBES!
Sounds like a bad connection of some sort; dirty tube socket, or even a dirty brightness control. I'd try tapping around on the chassis, and see if it makes the picture pop on & off. IIRC, that year of Magnavox (higher end models) also has an automatic room light sensor, which can cause issues. I don't remember what Magnavox called it, but it was some catchy name indicating auto brightness. Try shutting that off (switch on the back, usually near the top with the vertical hold, etc).
Charles
Old 10-07-2013, 12:56 PM
Look at the chassis with the back removed, in a darkened area. Take notice if the horizontal output and the damper tube is lighting properly, as well as the CRT. Also, make sure the horizontal output isn't red-plating, indicating the horizontal oscillator, isn't starting up, as fast as it should.
Old 10-09-2013, 07:27 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
I believe that room light sensor was called a Lumisponder.
Old 10-13-2013, 02:57 PM
Tubejunke's Avatar
Make sure that the C.R.T. plug has not loosened and causing the tube's heater not to come on perhaps until the warmth of the other tubes or movement, shaking or something else completes the circuit. This is very common and normally easy to fix.
The "plug" is the plastic end of the C.R.T. with the pins sticking out. The socket is the hard wired piece that connects to it. Just see if it (the plug) feels loose, but be gentle. If it is loose and the set is powered on, then you can move it slightly and see the darkness turn to light when you hit the right spot.
If this is your problem then we can go into detail on possible solutions. Good luck!
Old 10-13-2013, 04:36 PM
Find out if its the HV or video first.
When on but "acting up" put the back of your hand near
the face of the CRT. If you have HV you will feel the static pull
on your hairs. Try it when working also to get the feel of it.
Its Gods built in free HV probe !!
If its a video or CRT problem you will always feel the pull
after the normal warmup time.
Try it & get back to us.
Remember TV repair is "divide & conquer".
Old 11-04-2013, 02:43 PM
Thanks for all the replies,
after tapping on a few things in the back,
the screen now comes up right away...
Not sure what it was, maybe the CRT plug as Tubejunke thought,
though it was on tight.
Well, glad it's fixed, Thanks for all the help!
Magnavox300
Old 11-05-2013, 07:19 PM
Tubejunke's Avatar
though it was on tight. Magnavox300
This may have been one of the most valuable lessons that you will learn in this hobby, and frankly I think you learned it the easiest way; with a c.r.t. I say this because with a c.r.t. you get to see the fix on the screen. Tubes have a pretty big design flaw being pins and sockets made of varying qualities of metal, most of which oxidizes over time.
Everything can appear to be "tight" and is in many cases like this where the plastic locating plug is the primary anchoring point. Meanwhile you have electronic connections often marginal at best or even open as would be the case here with the final possibility of voltage dropped to a point so low as to not be able to rated potential.
With any tube equipment it is essential to get a cleaner for electronic parts and go through all tubes cleaning the tubes and the sockets. They used to make cleaners especially for this along with tuner contact cleaner which worked just as well like DeOxit and such. The trick is to take an old pocket knife or what have you and scrape the tube pins until they shine. It's not hard; just a few swipes and you can often cover more than one pin at a time. Spray the socket and insert, remove and reinsert the tube several times to help clean the socket. You will be much less haunted with misguided troubleshooting this way. Hope this helps!
Old 11-07-2013, 03:50 PM
Thanks, good advise!
I think I'll take an hour and clean the tube pins, and sockets with Deoxit...
I remember once reading you shouldn't scratch the tube pins, since they are coated? I would rather go with your suggestion, and get them bright again and not worry about it, I'd rather have a good connection...
You said use a pocket knife or something and scrape them till they shine,
are you sure that's okay to do?
Old 11-07-2013, 06:41 PM
I had trouble with my Admiral bakelite console, in that the CRT would go dark from time to time. I cleaned the pins of the CRT some years ago, and this problem hasn't reappeared.
