Old 10-12-2013, 08:02 PM
duckland 23's Avatar
duckland 23 duckland 23 is offline
Sony kv40xbr800 seven blink question
My television will work fine them for maybe two weeks or so shut off and sometimes turn back on again . Nut before she will shut down the screen will turn kind of pink with no video and then shut down . Sometimes before it happens it will look messed up like the color out of tune . I do get seven blinks when she will shut off . I bought the OEM Sony chips MCZ3001D NOT DB . Im wondering if I also have a problem with the guns on the set shorting out Just wondering what kind of problems sony television can produce .
Old 10-13-2013, 07:47 AM
Turning pink may be the CRT getting an H-K short.
Best test is light tapping of the neck while running to
see if you can trigger it. If it does look for bad PC cons
on the CRT board also. A shorting red output can also
do it, just swap with the G or B output to test.
Beyond that you will need manual & equipment.
Old 10-16-2013, 09:24 PM
I found in the service mode it telling me code 4,6,7 . that's the chips mcz3001d right causing this . I hope its not the tube .
