Old 10-25-2013, 09:56 PM
miniman82's Avatar
First Light: 1952-2011
Finally won a remote
Got here super fast too, had it in my hands 2 days from the time I paid for it.
Which chassis does this go with (CTC-?), most of the ones I see have clear buttons.
What shall I control with it? Possibilities include my Director 21, Wingate, or the Anderson.
Evolution...
Old 10-25-2013, 10:52 PM
I was looking at that one for my CTC10 but wasn't sure if it was compatible since it's newer.
Old 10-25-2013, 11:27 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Whatever you want. Re-tuning is always possible.
Old 10-26-2013, 12:42 AM
Steve D.'s Avatar
Steve D. Steve D. is offline
Nick,
Closest I can come is your remote is for the CTC-12, 15, 16, 16X, 17, 17X
The CTC-12 transmitter is CRK5A. The transmitter for the CTC-15 thru 17X is CRK6A.
Doesn't exactly pin it down but maybe the #'s & schematics will help.
This info from the RCA Field Service Guide 1955-66.
Kind of curious how you would adapt the remote to your existing sets having just a transmitter?
-Steve D.
Old 10-26-2013, 12:45 PM
miniman82's Avatar
I assumed the model would be on the circuit board somewhere, but sure enough the inside cover says CRK-6A, 1964, so it's the first one you posted.
Evolution...
Old 10-26-2013, 05:53 PM
Jon A.'s Avatar
-Steve D.
I hear that it can be done with a frequency counter hooked up to a microphone. In lieu of that, the oscillators will have to be adjusted a little bit at a time while observing for proper button response.
Old 10-26-2013, 10:40 PM
rick65's Avatar
rick65 rick65 is offline
That's that same remote used in my CTC-12 pictured. I actually have about three back-ups. Questions is where to order the Eveready #206 battery.
Old 10-27-2013, 01:02 AM
Steve D.'s Avatar
Google Eveready #206 battery or try this site:http://www.batteriesinaflash.com/spe...1611-h-7d-h-6d
-Steve D.
Old 10-27-2013, 10:34 AM
miniman82's Avatar
I ordered from here: http://www.genesislamp.com/206elcobainb.html
Evolution...
Old 10-27-2013, 07:13 PM
Adam's Avatar
Adam Adam is offline
I did a quick test using that remote on a ctc-9, with a AA battery (I don't know what voltage it takes, and the AA fits where the 4.5V battery I have in the older ctc-9 remote is too small to fit in this remote). The tint-down moves the tint up, the color-down moves the color up, the volume-down moves the channel, the channel moves the volume-up. The tint-up, color-up, and vol-up do nothing. The range is only a few inches from the receiver, but that might be due to the battery.
Old 10-27-2013, 10:54 PM
damen's Avatar
damen damen is offline
Here are some specs on the remotes that will explain why they are not interchangeable one a sens a pulse signal and the other does not.
Old 10-28-2013, 12:51 PM
6GH8cowboy 6GH8cowboy is offline
3.6 volt computer batteries are readily available and will fit. They will work on a variety of voltages but 1.5 is not one of them. The frequency can be checked with a bare open probe to a scope or counter. Just hold it in front of the mic opening.
There are a number of production variables that make these a challange. Have worked on several of these lately. There are a number of pitfalls the these old cuties, be careful.
BTW a 9volt battery can make enough drive to arc-over at the element!
