Old 10-28-2013, 08:13 PM
Does dust on tubes cause bad performance?
Hello does dust on tubes cause bad performance? I heard it does I was always told when I worked In tv shops to clean the ubes give me your honest opinion.... Timothy
Old 10-28-2013, 08:42 PM
JohnHacker1's Avatar
JohnHacker1 JohnHacker1 is offline
I would think that a clean tube would dissipate heat better.
Looks better, too...
Old 10-28-2013, 09:04 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
Dirt on high voltage tubes causes leakage, and leads to arcing.
Old 10-28-2013, 09:48 PM
bob91343 bob91343 is offline
In general, it's cosmetic. If you work on a set and clean the tubes, the curious customer will be happy. But dusty tubes smell nice, I think.
Old 10-28-2013, 10:21 PM
radio63's Avatar
radio63 radio63 is offline
Still Y2K Compliant!
This is one time I wish VK had a "like" button!
I don't know anything about ignorance and I could care less about apathy.
www.galaxymoonbeamnightsite.com
Old 10-29-2013, 08:58 AM
The HV rectifire & regulator should be clean to prevent arcing.
It was common to find a set with an inch or two of dust
in them, they went outside & got blown out. If you clean them
be careful not to rub the markings off. We had a few do that
& had to bring the set in for us to figure out were things went.
Also had a helper that cleaned things. Once he cleaned
" all that black crap" off the CRT ! Man did it shine.
I had to pour the boss a drink to calm him down. Next day we
were all laughing about it.........
Old 10-29-2013, 11:28 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
I've seen radios and TV's with lots of dust around the tube pins, and cleaning the dust out improved performance.
Charlie Trahan
Old 11-08-2013, 09:13 AM
Reece's Avatar
Reece Reece is offline
And a radio with a dirty variable tuning capacitor can work noisily and erratically.
Reece
Old 11-10-2013, 11:46 AM
zenith2134's Avatar
I was having an noise issue on my tube portacolor which came back to a faulty connection at one of the tuner pins. In fact I make a habit of cleaning the pins and sockets out really well any time I test tubes or change them. Keep in mind also, that the sockets are often faulty or include cracked solder points underneath, even if p-t-p wired.
