Old 11-04-2013, 02:38 PM
Fant's Avatar
Fant Fant is offline
Predicta Plastic CRT cover
I have a table top Philco Predicta with the CRT mounted on top. The plastic CRT housing is frosted, molded, and milldewed. What would be a good way to restore and clean it?
Old 11-04-2013, 04:34 PM
rob Cashin's Avatar
rob Cashin rob Cashin is offline
if its pitted, you probably wont be able to get rid of that, but i found that windex with a small buffer makes excellent results, but the vinegar kind not with ammonia. after its cleaned buff it out with turtle wax and it should shine like the sun.
Old 11-04-2013, 06:14 PM
It's not mold or mildew. It's the Tenite plastic breaking down. Try some Novus #2 plastic polish.
Old 11-04-2013, 07:42 PM
ISawItOnTV's Avatar
ISawItOnTV ISawItOnTV is offline
I wet sanded mine using 600grit-to-3000grit sandpaper (600>800>1K>1.5K>2K>3K). Started out with mineral spirits wet sanding, and last stages with warm water. Couldn't find Novus locally, so I used Meguiar's plastic cleaner and plastic polish (found at auto stores).
"I know it's true, oh so true, 'cause I saw it on TV"—John Fogerty
Old 11-05-2013, 11:39 AM
rld-tv01's Avatar
rld-tv01 rld-tv01 is offline
After looking around, I finally found out that harley davidson stores sell Novus. I got mine there.
Old 11-05-2013, 12:38 PM
For any polishing job, I try the milder solution first, and resort to coarser materials only if necessary.
If Novus alone will work, that will save you a lot of time over sanding it down and then gradually smoothing it back out. I'd polish a small test area with Novus and see where that gets you.
Phil's Old Radios
Old 11-05-2013, 04:34 PM
Fant's Avatar
I found a good price and supplier on EBAY for Novus.
Old 11-21-2013, 12:26 PM
Fant's Avatar
The Novus worked good. I would like to clean the inside of plastic and the CRT glass. When I remove the gold band will the CRT try to fall out? Is the CRT mounted or just floating inside the case?
"You want it WHEN?"
Old 11-21-2013, 12:27 PM
the crt is mounted inside so if you remove the mask the crt will stay in place.
mike
