Old 11-11-2013, 11:24 AM
Magnavox300's Avatar
..better in black & white
Testing a CRT-Should I remove this wire first?
Thanks to OLDTVSANDTOY sending me a B&K, I can now test my CRT...
There are two pins on the CRT socket that are connected together by a wire,
I wasn't sure if I should remove this wire before attaching the CRT test socket, or leave it in place?
Old 11-11-2013, 11:50 AM
I always removed them, just in case, not to cause damage to the CRT tester.
I see the focus pin is at ground potential. It must have the best focus there.
Old 11-11-2013, 08:33 PM
Thanks, removing it worked!
Old 11-11-2013, 09:19 PM
oldtvsandtoy oldtvsandtoy is offline
Banned
did the B&K 440 work good for you?
