Old 10-27-2004, 04:02 PM
joe_tbird
Guest
Posts: n/a
Zenith AM/FM radio loses signal.
I have a 1959 Zenith AM/FM table top radio (I believe it's model 845, but not sure). It's played fine for about a year, but recently when I play it on FM, it doesn't lock in a station unless I adjust the tuner. Once picked up, it will periodically lose the signal again (without my having touched anything). When that happens, I have to ever so slightly turn the tuner again to make it right.
The tuner feels tight (no excessive play), and the sound is otherwise good. Is this a sign of a pending electronic problem I should address (a failing tube or capacitor)? I don't know the radio's history, and am not sure if it's ever been recapped.
Thanks,
Joe
Old 10-27-2004, 04:22 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Sounds like you have a capacitor changing values as the set warms up. Does it ever get to the point to where it doesn't drift anymore? It could also be tube, which of course would be easier to change... possibly the oscillator.
Hey Joe... how did you make out with your 1955 Motorola? Hadn't seen you around for a while, and I've been wondering about it.
Charlie Trahan
Old 10-27-2004, 04:24 PM
RocknRoll
Guest
Posts: n/a
Is the model # C 845 L, M, W, or Y with Chassis 8C02? There is a schematic. Could it be the AFC tube or circuit? What is the tube lineup in yours?
Old 10-27-2004, 05:43 PM
joe_tbird
Guest
Posts: n/a
The tube layout is:
35C5
19T8 6AB4 12AT7
12AU6 12BA6 12BA6 6BJ6
Chassis C02 (may be the letter "O" or a zero)
Tube positions are shown relative to their acutal position in the chassis when viewing it from behind with the rear access cover removed.
Old 10-27-2004, 05:47 PM
joe_tbird
Guest
Posts: n/a
To answer Charlie's question about the Motorola.
Charlie,
Thanks for the suggestion. As to the status of the '55 Motorola, I've discovered the flyback transformer is going bad. I'm currently working with a gentelman named John Horvath at Amptech systems to try to locate either a replacement (not likely to find one), or someone who can rewind the old transformer. So far, no luck.
Joe
Old 10-28-2004, 11:19 AM
Chad Hauris's Avatar
I would replace the selenium rectifier in the power supply with a silicon diode with a 50-100 ohm 10 watt resistor in series with it. Was working on a Magnavox 50's FM set that would not tune above 98 mhz and the FM sensitivity was really poor: replaced the selenium with new silicon diode and performance is much better.
Chad Hauris
Old 10-28-2004, 01:50 PM
Nick_the_'Nole's Avatar
Nick_the_'Nole Nick_the_'Nole is offline
I have one with the same chassis that was doing the same thing. I replaced one of the tubes, I think it was the 12AT7, and the problem went away completely. Also seems to pick up stations clearer now, but that might be my imagination...
Old 11-02-2004, 03:47 PM
joe_tbird
Guest
Posts: n/a
Thanks for the suggestion. I replaced it with a new production Ei 12AT7 tube and the problem has gone away completely.
Looks like I'm back in business.
Joe
Old 11-05-2004, 02:26 AM
Chad, I have a 1963 Zenith radio with a selenium rectifier. The set still works well, no problems (yet) with the rectifier or anything else. Sensitivity is great, it sounds fantastic, so I really don't want to go into it unless I have to. What could go wrong with a selenium that has been working well for 41 years, no problems? I would think if the thing hasn't shorted by now, it should go for years. I always thought the only way seleniums ever went bad was if they were accidentally shorted (as you once mentioned happened to a Zenith radio you had, in which a headphone jack worked loose and fell on the stack); never thought they could short or open on their own.
Old 11-05-2004, 02:39 AM
RocknRoll
Guest
Posts: n/a
I have heard when they start to go bad they smell like rotten eggs or burning sulfur. Never smelt one this bad, but I do agree they should be upgraded with silicon.
