Old 12-06-2013, 02:42 PM
Josef's Avatar
Josef Josef is offline
German Prototyp TV
This very interesting set was sold on ebay for a remarkable price:
http://www.ebay.de/itm/Spiegelbild-F...p2047675.l2557
The stamp on the circuit diagram means that the set was not approved for construction.
Greetings Josef
Old 12-06-2013, 11:28 PM
baursam's Avatar
baursam baursam is offline
Thank you Josef for posting. I find it very interesting to see early examples of TVs from Europe. Just don't get to see them very often
Old 12-07-2013, 01:44 AM
Cool set, I can see why it wouldn't be approved, it's insanely dangerous with all that circuitry just a key turn away!
A kid like me would have had that open in no time, Zzzzap!
Old 12-08-2013, 07:42 AM
tubesrule's Avatar
tubesrule tubesrule is offline
Interesting set Josef. It appears to be a recreation by someone of a early design. That must have taken a lot of effort!
Converters for obsolete standards:
www.tech-retro.com/aurora-design/legacy.html
Old 12-08-2013, 10:09 AM
Kevin Kuehn's Avatar
Workin' Late Again
That's some pretty impressive build construction. Nice and orderly for easy serviceability.
Old 12-08-2013, 02:56 PM
Tom Albrecht's Avatar
The chassis looks like it might be original. However, with it apparently in working condition, I wonder if its capacitors have been restuffed, or somehow replaced with replicas?
The cabinet looks too clean to be original, although the little number plate and red marking inside looks original, as does the paper tube diagram on the inside wall. Somehow this was kept very clean, perhaps enclosed in a box for most of its life?
Old 12-08-2013, 03:34 PM
Seems odd that it has a vertically mounted pre-war type CRT, but uses post-war miniature tubes The description says it was made in the early 50s.
Old 12-08-2013, 03:38 PM
tubesrule's Avatar
That's why I was thinking it was a recreation although it does look like the prewar Telefunken FE series and is marked FE 25 so perhaps this was a post war effort by Telefunken using parts they had on hand and newer parts like the miniature tubes?
Old 12-13-2013, 03:04 PM
Josef's Avatar
At first I had similar ideas. So I thought that the set might have mains EHT because of the ununsual construction of the power supply but it hasn't. The CRT is an early 1950s construction as you can see on the spec sheet of this tube:
http://frank.pocnet.net/sheets/030/m/MW31-16.pdf
Never the less the whole mechanical construction is really old school and nice to look at. That was the reason why I have posted this link.
Greetings Josef
Old 12-13-2013, 03:49 PM
TheX TheX is offline
I like that!
