Russian radio,a suprise
Bought an old Russian communications radio,quadruple change superhet with 6 RF stages,bandspread tuning,twelve if stages,along with a 2kva transformer to convert 240v to 220v,for 50 bucks from a junkshop,had to replace one of the 5 filter chokes,and all the 700uf 1kv reservoir and filter caps,all the paper caps were oilfilled 5kv rated so these were ok, 2 PL519 sweep tubes in class ab for audio,also had FM,65-120mhz and airband too,thing was built like a tank,all the knobs worked the wrong way,opened it up,in a small compartment was a comprehensive service manual,in English,and Russian,along with a picture of Joesph Stalin being riddled with bullets,by someone from the Klan,along with a loaded Makarov pistol,with a tag,Greetings,comrade,from the CIA.Any you guys found stuff like this before?
