Old 12-27-2013, 10:56 PM
John Marinello's Avatar
<-- "Byron"
CRT Press photo
I don't get this one:
http://www.ebay.com/itm/1954-Press-P...item5af97d64ce
I wonder if the CRT is under vacuum??
Old 12-28-2013, 06:00 AM
danny danny is offline
Danny
Hi it probrably was under vacuum less safety regs then.
Old 12-28-2013, 09:32 AM
Could be completely staged, could be something holding up the kid. It's textured plywood, possibly done outside with the kid's weight not on the tube, and there could be people just out of frame, set the kid and tube in there and snapped it really quick....
Old 12-28-2013, 09:34 AM
Probably not very risky unless the kid had something hard to scratch it.
Sent from my LG-LS970 using Tapatalk
Old 12-28-2013, 01:02 PM
The entire surface of the tube normally withstands 14.7 pounds per square inch (one atmosphere) and I believe that most designs were tested to 2 or 3 atmospheres. The additional weight of the child (20-30lbs?) is really small in comparison.
Old 12-28-2013, 04:30 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
That wasn't the last "Kid with Big Tube" ad, either. Eimac put out this one in 1971...
Old 12-28-2013, 05:00 PM
My all time favorite scary CRT publicity picture is this early DuMont photo:
Looks to me as if the getters in the 20 incher are silver but perhaps the smaller tube is up to air?
Old 12-28-2013, 05:24 PM
dtvmcdonald's Avatar
The picture you want is 11,000 20 inch tubes under water in
a lake, with people in a boat examining them.
Imagine what would happen if one under water broke ....
many, many others would break due to the shock.
This actually happened! 7000 broke. These were photomuultipliers.
Google Super-Kamiokande accident.
Old 12-28-2013, 06:46 PM
That gal is smiling, but I DON'T think she's entirely HAPPY...
Old 12-28-2013, 11:06 PM
I had friends who did random work on used or junked TV sets in the early 1980s. One time, they showed up at my house driving a Suburban-type large wagon with only a front seat (or maybe the back seat was folded down). The entire back was filled with large CRTs. Loose ones! They were not even in a single layer or all face down if I remember right. I just imagined what would have happened if they hit a good bump in the road, much less had had to hit the brakes hard.
Old 12-30-2013, 10:52 PM
Telecruiser's Avatar
Telecruiser Telecruiser is offline
When I was In High School, my first job was at a local TV repair shop. We used to collect a bunch of CRT's that had no dud value. After a while we had to get rid of them, so we would load up 15-20 of them and take them to the town dump. Another kid my age worked there too, and the two of us were usually elected to get rid of the tubes. To make this more fun, we used to see how far we could throw them; the best implosion on ground contact won. Amazingly out of all those tubes, only one or maybe two would make any significant noise. Most survived being hurled 20-30 feet. It seemed that only the 110 degree tubes were easy to break. From this experience, I discovered that despite common folklore, these tubes were very strong.
Now just because I said they are hard to break doesn't mean you should be foolish around one. Be sure to take all safety precautions when you handle one. It only takes one bad implosion to ruin your day.
Old 12-31-2013, 05:13 AM
peter scott's Avatar
peter scott peter scott is offline
Looking after the baby seems to be a common theme:
Old 12-31-2013, 05:36 AM
Steve McVoy's Avatar
She looks scared to death:
Old 01-21-2014, 06:35 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
IMHO that's a baby actually worth having. One-time investment, no noise, no mess.
