Old 01-01-2014, 10:10 PM
legenbass77 legenbass77 is offline
10HE Portacolor problem
Well I got ready to watch a movie on my Portacolor, but unfortunately the picture never came up. I did hear the high voltage come up, have sound, but no raster at all. Static on the screen felt normal, but don't have a high voltage probe to confirm. All tubes filaments are lit including the crt. I can hear the vertical circuit running, because I can hear it change when I turn the V-hold through it's range. I thought maybe I turned the brightness down while dusting, but that did nothing. Wiggling the tubes did nothing. No strange smells, or burning smells. Set worked great last time I used it about a month ago, and didn't even do the color change problem. Seems like something went open. I don't have a schematic. Any help would sure be appreciated.
Thanks!
Old 01-02-2014, 03:29 AM
A way to test for HV is to try and draw an arc off the HV line at an exposed point(HV rect socket in HV, cage or unplugged suction cup). Depending on the set 1/4" to 1.5" should indicate decent HV.
If there are any TV repair shops in your area that service CRT sets you might be able to talk them in to letting you borrow their probe or having them measure the HV.
I have a portacolor and a copy of the sam's so I'll try to get you the CRT voltages tomorrow afternoon.
Old 01-02-2014, 06:49 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
I never felt comfortable doing that, myself. I picked up a neon bulb from Radio Shack, clipped the leads short, and taped the leads to the body of a bic pen, with the refill and guts removed. Put the neon bulb near the flyback or HV anode, and if there is HV, the bulb will light.
Old 01-02-2014, 01:56 PM
On the HC chassis HV should be 15-18KV with 16 reccomended. Cathodes should be at 220V, grids at 175V, Screen grids 530-600V (though from the wiring it looks like they can be set between 270-670V). The focus is listed as DO NOT MEASURE and is connected to either ground, 270V, or the 670V boost.
The neon test is great if you don't have the nerve for the arc test or if your set has a fairly low HV, but I like the arc length better as I can get a quantitative measure of voltage based on arc length VS arc length of a known votage...My HV meter is DC only so I can(and had need to) guage an AC high voltage by arcing a known DC voltage and comparing arc length.
Good luck getting it going.
Old 01-02-2014, 06:23 PM
Ok so I pulled the cap off the hv rectifier tube, and got a pretty healthy arc. Not much room to move the cap in that little cage, but I could get a good half inch arc moving the cap away from the tube before it would start arcing all over the place. Now on measuring the cathodes, grids, and screen grids. Which color wire corresponds to each tube component to be measured? I sure don't want to mistakenly try to measure the focus wire. I did use the neon bulb test too. The neon lit up in the hv cage area, but not outside leading up to the anode cup. It barely lit up when I touched it to the tripler. Could the tripler have failed? Thanks for the tips so far.
Old 01-02-2014, 06:52 PM
neon will not light up around the anode, needs the AC not the DC. It may flash but will not stay lit. It could be a bad HV rectifier tube. I would just pop for a HV probe, if you are going to own vintage TV's you need to learn how to work on them and the tools to diagnose problems. If the HV is not there and you have a good arc at the plate cap of the HV rec tube then a good chance the problem is the HV rec tube.
There is no tripler used on tube portacolors, maybe a focus divider if you have the high voltage focus set. should not lite up around that either, again DC.
neon should lite up around the horz out tube, the top of the HV rec tube and anywhere near the fly.
If HV is there, I would look at the CRT pin voltages as mentioned for where to look next.
Not sure about this, but on reg color sets you need the focus voltage or the raster goes away. With the high focus voltage PC's maybe the same in which case you will need to confirm there is focus voltage at the CRT pin (if the other CRT pin voltages look good). I use a simpson 260 5000vdc to check focus voltages. you can also use the HV prob as well for focus, just not as good resolution as the simpson.
IF focus voltage has gone away, then I would look at that divider off the HV anode.
Old 01-02-2014, 07:09 PM
The black block with red & green wires sure looks like
a focus divider. Newer PC did have a high focus jug.
So I would be suspect about the focus voltage from Sams.
Hows about putting up the model # may be more than one version.
Old 01-02-2014, 07:28 PM
Model number is WAHE5223RW! The lack of voltage around it up to the anode sure caught my attention. Is this a fairly common failure mode for the focus divider to be working with no symptoms of imminent failure to be dead next time the tv is powered up?
Old 01-02-2014, 07:46 PM
Thanks Dave, you are right about getting some more test equipment. I just got done looking at hv probes, and will definitely get one. It's an interesting hobby, and I'm up for learning how to do it right, and this seems like a good forum to learn. I don't want to just start throwing parts at it. You know I didn't even consider the dc vs ac on the neon, duh! I'll check out the Simpson 260 as well. Sorry for the terminology mix up calling the focus divider a tripler. Not sure why I had that on my mind. Tom what would you charge me for a pdf copy of that schematic? Thanks again for the wealth of information. Ok I have the socket off the crt ready to check the voltages what is the pinouts that correspond with the voltages I'm looking for? Grid pin (x) screen grid (y)...
Old 01-02-2014, 08:20 PM
Here is the voltages I got on the crt socket. pin 1: 140v, pin 2: 16v, pin 3: 182v, pin 4: 164v, pin 5: 23v, pin 6: 177v, pin 7: 164v, pin 11: 164v, pin 12: 55v, pin 13: 175v, pin 14: 144v. pin 9 appears to be the focus wire, so I didn't measure it. Pin 8, and 10 unused.
Old 01-02-2014, 09:41 PM
1,13,3 are low, G2 screens should be up in the 500v range. My guess is a shorted boost filter cap. see if there is a .1 mounted kinda near the flyback up high. Think that is where they put those. some are down low near the damper. The screen pots (3 in the middle of the set back) should have B+ on one side and boost on the other.
Its a big white ceramic 1kv maybe higher tubular cap
those voltages being lower that typical B+(270v) may point to a low voltage supply issue. Maybe a shorted filter cap or doubler. These are in the large can multisection caps.
Its a good idea to replace that boost filter (the .1 at 1kv) as well as the .047 (another typical white tubular cap that sit upright near the damper on the back of the set) as both of those are paper caps that frequently can leak. If it has a bumblebee across the line, replace that as well with a good Y rated safetycap.
You can test the output from the B+ with a DMM should be 270v. there is a double circuit for the LV B+, one of the diode cathodes leads should be 270vdc, one will be lower. the one you want is the one that goes to a filter cap AND choke.
Old 01-02-2014, 11:17 PM
I'm getting 265v at filter cap that connects to the choke, and getting the same at the screen pots. I clipped on to the lead from the triple pot where 280 volts is printed on the circuit board. I did locate all the suspect white caps, and there is a white .039 @125v across the line. Well I'm gonna call it a day. I've got to head out of town for a couple of days. I'll get back at it by Sunday hopefully. I sure appreciate the help!
Old 01-03-2014, 05:10 AM
seem odd that you are getting less than 265 at G2. those pins connect to the center of the pot, with one side at +265 and the other at boost, then you should be getting a min of +265 unless the boost is less than that. If you swing the screen pots to the max CCW they should be +265. Def something odd going on there. Good luck with it.
Old 01-03-2014, 08:02 AM
Pulled Sams for the model # it says "similar to chassis"
so may be some differences.
670 boost comes right off pin 3 of the FBT to one end
of the screen controls. Only other thing is 2 caps.
A .01 1.4KV to ground (cant find)
A .1 1KV to the 270V big white one by hoz out tube.
FBT should measure 8.7 ohms pin3-6
Old 01-03-2014, 11:12 AM
