Old 01-24-2014, 08:18 PM
National TV-7W
Seeing a National TV-7W on ebay got me thinking it was about time I took a closer look at mine.
I got it from the Elli Buk auction last spring sandwhiched between a Clifton and bakelite Emerson.
I suspect it was that very heavy Emerson that caused the top to mush down and front to pop out. Hopefully, it can be jacked up, glued and clamped back in place.
I'm pretty sure only the fine-tuning knob is correct. I suspect it will be very hard to find a full set of correct knobs.
There seems to be two versions of this set. This being the early with series string tube filaments, logo above the screen and no holes for a magnifier.
The only good picture I could find online was from the ETF
Here's an example of the other version.
I'm pretty sure that's a homebrew back.
It kinda looks like two labels were removed and this one applied.
Two fuses are a nice touch
Old 01-24-2014, 10:33 PM
mpatoray's Avatar
mpatoray mpatoray is offline
Looks like an interesting set. Is this an Electrostatic one?
Old 01-24-2014, 10:36 PM
David Roper's Avatar
console lover
Definitely yes.
tvontheporch.com
Old 01-24-2014, 11:06 PM
Yep, 7JP4 electrostatic CRT.
Now for the inside.
The AC line voltage selector is a nice touch.
Solid plywood bottom.
Simple cabinet interior.
Finally, here's the chassis with dual speakers
Loads of room underneath. Should be a piece of cake to work on
Old 01-24-2014, 11:11 PM
I like they way the constructed the HV section with clip-in doorknob caps the horizontal deflection coupling.
Multi-deck rotary tuner switch.
Cast aluminum fine-tuning gears.
Crappy old repair.
HV oscillator coil. I sure hope it's still good
Old 01-24-2014, 11:15 PM
Now for a bit of cleaning.
Chunky piece of safety glass.
Ceramic sockets for the hor/vert oscillator and output tubes.
It's a guaranteed electron tube
That's better
Old 01-24-2014, 11:24 PM
mpatoray's Avatar
That set is looking nice, the chassis is in great shape! Dual oval speakers, that should put out some dB's Looks like it is going to turn out to be a nice set.
Old 01-24-2014, 11:47 PM
That is just about my favorite 7-inch set. Only National would give you ceramic tube sockets!
That chassis will polish nicely, too, if you're into shiny.
If I could only keep one 7-inch, it would probably be my Admiral 19A12, though. Performs very well and it just looks so darned cool.
Phil's Old Radios
Old 01-24-2014, 11:55 PM
Very nice
I think my favorite 7" is the Airline 94GSE31088, but then I've never owned one and probably never will.
Old 01-25-2014, 12:39 AM
I should have said, "of the 7-inch sets that I own," the National is one of my favorites. I'll probably never run across one of those Airlines, either.
I'll be curious to see what you think of the National's performance when you're done. I think it's a pretty good set, but there are lots of things I haven't seen (and I did the restoration on mine a long time ago).
Regards,
Old 01-25-2014, 12:54 AM
The schematic in Riders #2 shows a dedicated AGC and DC restoration rectifier so I expect it will work fairly well
Old 01-25-2014, 09:31 AM
TV'S&MORE TV'S&MORE is offline
Hi Bob,
This is going to be a great project. I look forward to seeing you do a full restoration. I have this same model only mine has channel 1 Most of channel selector knobs I have seen are chicken head knobs. On the chicken head version the fine tuning knob is the size as the volume knob. Based on your photo it looks like yours is the chicken head version because of the size of the fine tuning knob. On the other version the fine tuning knob is smaller. I usually only see the knob that covers the fine tuning in the later version models like the photo you show with the magnifier option. I am sure either would be appropriate. Hope this helps.
Roy
TV’S&MORE
Old 01-25-2014, 11:36 AM
rld-tv01's Avatar
rld-tv01 rld-tv01 is offline
I was thinking you could get knobs off an old National TV signal booster but it appears they only have one knob. You could use that knob to make your own. Sometimes you can get these boostewrs cheap on eBay for $5-$10. http://tv-boxes.com/boosters/natl-tvb2.jpg
Old 01-25-2014, 01:49 PM
rld-tv01's Avatar
It seems National couldn't decide whether to put their logo on the top or bottom of the face. A picture of one of two that I have with the logo on the top.
Old 01-25-2014, 08:42 PM
earlyfilm's Avatar
Eternal Member
Bob, go to closed ePray auction 231124855530 , and select "see original" and you will find two original adverts for this set, one (or both?) which seem to show a modernistic brown chicken head, instead of the later style knobs.
The pictures of the restored set in the auction show the more common knob. The seller is the green pool table guy in Florida.
Jas.
Last edited by earlyfilm; 01-25-2014 at 08:50 PM. Reason: Forgot to mention 2nd ad in pictures
