Old 01-31-2014, 12:31 PM
miniman82's Avatar
First Light: 1952-2011
Lectrotech V-7 Vectorscope- need instructions
Just got a working one off fleabay, but I don't know how to connect it...
Evolution...
Old 01-31-2014, 03:03 PM
hey i ask the same question around 6 months , i found a schematic only so far but no manual so if you find one i would like a copy to. mine was new in the box with one dead shorted cap. the cap just under the crt. plug, i forget the value off hand i would have open it back up .
Old 01-31-2014, 10:05 PM
ChuckA's Avatar
ChuckA ChuckA is offline
I found a copy of the instruction manual in my library, it's posted on my WEB:
http://www.myvintagetv.com/manuals_and_documents.htm
Chuck
www.myvintagetv.com
Old 02-01-2014, 05:31 AM
Chuck
many thanks for the v-7 manual
Old 02-04-2014, 04:24 PM
miniman82's Avatar
Thanks for the manual!
Man, mine has been messed with like a million times. Lots of different value resistors in it, and it's not running on frequency either just like my RCA one. It's strange though, I can get a proper color bar pattern out of this one but the crosshatch and dots function is all screwy. Is there something specific to those functions that would cause them not to work while the color bars are fine?
Evolution...
Old 02-04-2014, 07:10 PM
thats funny you say that mine is doing the same thing, after finding the dead shorted cap, i went ahead and replaced all the ceramic caps. and after that i had a hard time getting the color bar and crosshatch to hold properly as soon as i thought i had it would drift out again ,so i thought before i keep shotgun diagnosing it i would get the right manual for it. when i get done later this week with what im working on now ill look at it again, if you find something let me know to.
Old 02-06-2014, 09:50 PM
miniman82's Avatar
Figured it out: my monitor was loading it down too much, causing the problems (I was using the composite output). There was also a slightly noisy color pot I had to clean, but it works great now. I'll post some pics later.
Evolution...
