Old 02-10-2014, 12:01 PM
radio nut's Avatar
Born in the wrong decade
crt sub
does anyone know if you can use a 5bp4 as a sub for the 5tp4 used in the rca projection sets from 1949?
Old 02-10-2014, 12:12 PM
Not even close... The 5bp4 is a scope tube with electrostatic deflection an 2000 volts max anode voltage. The 5tp4 is a magnetic deflection tube designed for projection that takes 27,000 volts max on the anode to produce a very brite picture.
jt
Old 02-10-2014, 12:23 PM
radio nut's Avatar
any substitute or source of those crts?
Old 02-10-2014, 01:20 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
I once had my hands on a 5AZP4, which uses a higher anode voltage, but has an integral HV lead.
Old 02-10-2014, 05:42 PM
Tubejunke's Avatar
Through the years I have often wondered if a tube with one letter difference could be at least usable as a replacement, but 9 times out of 10 it is out of the question. There are subs, or what could be used as subs with some circuit changes, but they sure don't go by the alphanumeric sequence. It would be nice if they did.
If you can ever get hold of a Sylvania or RCA tube guide from the 50s like I have, you will have an invaluable resource. I'm not so sure how hard they are to find these days.
Old 02-10-2014, 06:05 PM
If you need a projection tube Radioalguy has a couple.
http://www.radiolaguy.com/Tubes_CRTs.htm
Old 02-10-2014, 06:58 PM
ChuckA's Avatar
ChuckA ChuckA is offline
Only sub for a 5TP4 is the harder to find 5AZP4
I've got a few loose ones, contact me off forum.
Chuck
www.myvintagetv.com
Old 02-11-2014, 02:07 PM
John Folsom's Avatar
And there is also the RCA 4820, also with an integrated HV lead, and another 40KV anode projection tube. I believe both the 5AZP4 and 4820 could be made to work in place of a 5TP4, thought the lower HV would diminish performance markedly.
John Folsom
Old 02-11-2014, 06:43 PM
A good way to find subs is to consult a period reference (or online posting thereof) and compare physical size of the envelope, deflection angle, type of focus, if it uses an ion trap, and electrical specks. If things are close enough or easily compensated for then it is likely to work
Old 02-11-2014, 07:49 PM
Steve McVoy's Avatar
We have a good one posted:
http://www.earlytelevision.org/pdf/cbs_crt_specs.pdf
Old 02-11-2014, 07:56 PM
I want one of those 7", 75,000 volt projection CRTs
http://www.akh.se/tubes/htm/7wp4.htm
Old 02-11-2014, 08:14 PM
Einar72's Avatar
Wear your Dosimeter faithfully...
Old 02-11-2014, 08:34 PM
Just move into a cat-scan machine.....
Old 02-11-2014, 08:42 PM
TV'S&MORE TV'S&MORE is offline
WOW that is too cool. never seen that before. I want one too.
Old 02-11-2014, 09:14 PM
Here is a prewar one using 80kv:
http://www.earlytelevision.org/rauland_crt.html
