Old 03-02-2014, 12:16 PM
CaryLee's Avatar
CaryLee CaryLee is offline
Anyone have a 1950's Centralab catalog?
Or know where I can find one on the net? I found a catalog from the 1940's but that's too early.
I'm trying to find the part number for the switch cover for the on/off, volume, and hold control on my 1950 DuMont RA-112.
The SAMS Photofact doesn't break down the individual components, but lists the a Centralab part number: SBB-560-S, which I believe is the whole assembly.
The switch cover MIGHT be a KR-1. Does that sound right? The IRC equivalent is a 76-1, but I don't know if an IRC cover will fit a Centralab control.
Thanks.
Old 03-02-2014, 01:36 PM
kvflyer kvflyer is offline
If you don't find what you want, you might try Mark Opatt. He can make just about any control.
http://www.oldradioparts.net/controls.html
Old 03-02-2014, 02:51 PM
CaryLee's Avatar
Thanks, I've sent him an email, but haven't heard back yet.
Old 03-02-2014, 04:16 PM
Kevin Kuehn's Avatar
Workin' Late Again
Looking at my Sams 1966 control cross reference replacement guide, the Centralab KR-1 should be correct. That's the complete switch assembly. I'm not aware that they sold a separate cover.
Old 03-02-2014, 07:20 PM
CaryLee's Avatar
Thanks Kevin,
I may be using the wrong terminology for the switch. I've seen them called "switch covers" on the internet, and I've befriended a local fellow who had a radio/tv repair shop back in the 60's and 70's (he was partners with my wife's uncle who's in his 80's and doesn't remember much from back then) who just called it "the cover".
It is the whole switch assembly I'm talking about, but it seems to just snap/crimp onto the back of the pots in front that do the volume control and hold control. Thanks for looking that up. There aren't many parts to "eyeball" out in my neck of the desert, so I have to buy from the net looking at pics and then hope it's right when it gets here.
-Cary
Old 03-02-2014, 08:04 PM
Workin' Late Again
Cary - You're very welcome.
I suppose people call them switch covers because the switch basically replaces the pots standard back cover.
Unfortunately there's no guarantee that a KR-1 switch will fit an OEM Centralab pot.
Old 03-02-2014, 10:09 PM
CaryLee's Avatar
That could be it. Maybe "switch cover" as opposed to "blank cover", or something like that.
The other option to trying to find a replacement switch is to replace the whole control. The SAMS photofact does list the parts breakdown to build the control from IRC parts. I might have to work on gathering them, and just replace the whole thing.
11-133 50 k ohm pot
13-137 1 meg ohm pot
202 shaft end
76-1 switch
-Cary
Old 03-03-2014, 10:21 AM
Workin' Late Again
If you could post a picture of your control, someone may have a parts donor laying around. Those switches had to be as common as dirt back in the day.
Old 03-03-2014, 12:15 PM
Kevin! Your #6 posting is exactly the answer, I was going to post.
How much of that stuff went to the scrap pile, way back then. Someone has to have one in the junk box or scrap chassis hoard.
I've worked on Dumonts, but not as many, as the Chicago makes. They usually used CTS, with Zenith using Mallory.
