Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > Transistor Portable Televisions
Old 03-29-2014, 03:15 PM
Bill R Bill R is offline
Goodwill finds
Today I found some small 5 inch tv's at our local Goodwill store. I know surprised even me. Here is a photo. From left to right a 1977 Sears, 1984 Sears, and on the right a Heathkit from the 80's. I will have to find some batteries to test the 77 model since it didn't have a power cord. The other two produce a snowy raster and all of them have 300 ohm antenna connections fo a balun to connect a converter. Grand total $17.50.
Old 03-29-2014, 05:05 PM
That Heathkit was also sold under the Zenith name, I had one for a while.
There are some AA batteries for the clock in a compartment somewhere, it gets overlooked and the batteries can corrode inside so find it and make sure they are removed.
Old 03-29-2014, 07:06 PM
The Heathkit is a GR5005 from August 1984. The batteries were in really bad shape. It will clean up though. It did have the Zenith wall wart power supply with it. The AA battery was behind the 6 D batteries that had corroded. I suspect that with a good cleaning and some new batteries it will work fine. On AC i do get a snowy raster, so it appears the major componants are working.
Old 03-29-2014, 07:07 PM
The battery compartments in the other two are fine. No corrosion.
Old 03-30-2014, 03:32 AM
VERY cool Heathkit! That was from after Zenith had bought Heath. I had forgot that there was a kit version of that (Taiwan-made) Zenith 5-inch B&W set. They were certainly the last USA-made black-and-white sets, then. Did they come with pre-assembled boards, I wonder?
Old 03-31-2014, 12:51 PM
trojanrabbit trojanrabbit is offline
I had that Sears set at one time. Not a bad performer.
Old 03-31-2014, 05:49 PM
It will be interesting to see if the heathkit was indeed a kit or just purchased assembled. When I get time to open it up maybe it will be obvious. I suspect the board with the IF strip and tuner would be pre assembled, but if there are any other boards they may have been user assembled.
Old 03-31-2014, 07:28 PM
If I remember right, items that were not available as kits were labeled "Heath" in that era as opposed to "Heathkit". I think I do remember seeing this set as a kit in one or more Heathkit catalogs. It was not cheap, maybe over $200 even, and also maybe equal in price to or more expensive than the built (Zenith) version, especially if the Zenith was on sale at an ordinary store.
Old 03-31-2014, 09:24 PM
As a kit the Heahtkit was $149.95 and fully assembled $179.95. The rechargable battery pack was optional.
Old 04-03-2014, 02:08 AM
Thank you for posting that catalog page and clarifying details. It could have been a factory-built set, then.
