Old 04-05-2014, 04:04 PM
radiotron's Avatar
radiotron radiotron is offline
johnny the raster master!
1959 zenith space command 300
Thanks to tvtimeisfun I have a new space command 300! Works great with original remote control!
Looking for zenith cobramatic parts
-johnny the raster master!
Old 04-05-2014, 04:11 PM
Jon F's Avatar
Jon F Jon F is offline
Adjust your vertical linearity!
TV looks good.
Old 04-05-2014, 04:27 PM
dishdude's Avatar
dishdude dishdude is offline
That's a pretty modern looking set for 1959. I love the large channel display!
Old 04-05-2014, 04:32 PM
radiotron's Avatar
TV looks good.
That's part of the bezel, you can't see it that well because of the lighting
Old 04-05-2014, 06:51 PM
truetone36's Avatar
electronics packrat
That looks more like a 1963-64 set to me.
Old 04-05-2014, 09:27 PM
robert1's Avatar
robert1 robert1 is offline
I Have the same model, except it is non-remote. according to the label inside the cabinet, mine was made in 1960. all metal cabinet makes it weigh a ton. i recapped the vertical output stage & replaced a open resistor in the horizontal driver/Oscillator stage several years ago & i am still using it as a daily watcher.
[IMG][/IMG]
that black bar going across the screen is from the camera.
Old 04-05-2014, 09:54 PM
According to the oracle of all knowledge (eBay) it's a 1961.
http://www.ebay.com/itm/1961-ZENITH-...item3f01ee7ecd
59, 61, whatever, it's a really nice set and you don't find many suitcase portables with remote any more.
Old 04-05-2014, 11:10 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Wow, never saw a channel indicator like that before. Remote-controlled too, sweet. I wonder if Zenith made any color sets with such a setup...
Old 04-06-2014, 12:13 AM
Not quite the exact same part, but non-remote color sets had tuning knobs with round number projection indicators like that. The remote models usually had the same type of display with a rectangular window.
Old 04-06-2014, 03:06 PM
Jon A.'s Avatar
Even so, that's another color set for the bucket list.
Old 04-07-2014, 07:56 AM
DavGoodlin's Avatar
Motorola Minion
Thats a nice example of a Space Command set for sure, and best for us TV techs to save the finest examples.
Let the Eames-freaks have the others, Zenith made the best sets then.
I saved a 1961 23" Zenith a few months back with the same knob as Robert1's set above, its now under my newly constructed work bench as a permanent watcher.
-Dave G
Old 04-07-2014, 08:29 AM
[IMG][/IMG]
The big power transformer, also adds to the weight. The remote model also has a transformer in the remote unit.
IIRC, that model uses the 3DG4 rectifier tube.
Old 04-07-2014, 08:39 AM
The projection indicators on Zeniths and other makes, used a special lamp bulb, 239 or 240. If you tried to use a #47, you couldn't get the numbers to focus properly. It had something to do with the filament placement. Even with the proper lamp, the adjustment was tricky.
Old 04-07-2014, 01:41 PM
robert1's Avatar
Mine uses a 5U4 rectifier. still has the original.
Old 04-07-2014, 02:26 PM
Hello it takes a very special person to get such a good set from me he deserves to own because he is a good kid besides he helped me get a late 50s telefunken console radio working he dives right in and produces progress on anything he does I am very proud to know him...Timothy
