Old 04-08-2014, 01:55 PM
boboh1's Avatar
boboh1 boboh1 is offline
Discharging TV
Will be starting to recap a couple of TVs. What is the best method to make certain the TV is discharged? I was thinking of taking the high voltage lead then touching it to the HV cage along with placing high watt resistor across the can capacitor leads. What do you guys think is best?
Old 04-08-2014, 02:03 PM
Caps most likely will be discharged after a day of being off...
Picture tube jumper lead from a screw driver to HV cage, push the screw driver under the hv attachment on the tube....
Old 04-08-2014, 03:26 PM
boboh1's Avatar
Perfect. Thanks for the info.
Old 04-08-2014, 05:19 PM
I recommend clipping the CRT anode button to ground, after discharging with a jumpered screwdriver and removing the HV wire from the tube. Or inserting a high value resistor in series with the jumpered screwdriver. Otherwise the CRT anode can 'recover' it's charge and bite you again in a few moments after it has been discharged.
I learned this the hard way on a Silvertone with a 21GUP22 CRT several years ago.
Old 04-08-2014, 06:03 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
Yes, the CRT is actually a very high grade low-leakage glass dielectric capacitor. Think really big Leyden Jar.
In a dry environment, they tend to "self charge" due to dielectric absorption.
Old 04-08-2014, 09:01 PM
boboh1's Avatar
Good to know. I will certainly do that.
Old 04-10-2014, 09:30 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
So, no voltage at the CRT pins but there is at the evac stem? Last tube I aired, after doing so I reached out to grab a piece of dangling glass and a spark jumped to my finger. Not a shock per se, but I could feel it and yanked my hand back mighty quick.
