Old 04-08-2014, 09:30 PM
CoogarXR's Avatar
CoogarXR CoogarXR is offline
Zenith 20XT20 Chassis Problem
Hey guys-
I don't know if you guys ever get into solid-state zeniths, but here goes.
I have a X930 console with the 20XT20 chassis. It sounds OK at low volume, but only with the bass knob at 75%. Any higher and the bass distorts. The higher the volume, the more you have to cut back the bass to fight distortion.
I have had this model before, and I know what it is capable of. The problem is on all inputs, and on both channels. I tried different speakers too. I pulled the chassis and cleaned all the pots and switches. That fixed some other issues, but it still sounds very flat and crappy.
Anything I should try? I could re-cap it, but I hate to just throw parts at it guessing. I wish I had an oscilloscope.
Old 04-10-2014, 09:11 AM
I would just do the electrolytic caps. One thing that can
fool you is if one channel is loading down the other.
If you have one ch drawing too much the B+ will be
loaded down & effect the good channel. If it uses speaker
coupling caps typ 500 - 1000mfd they caused trouble also.
Unfortunately I dont have a manual for it.
good luck 73 Zeno
