Old 04-26-2014, 08:24 AM
DavGoodlin's Avatar
Motorola Minion
CRT tester not so universal
I almost condemned a perfectly good CRT, a 19CUP4 in a 1964 Philco BW table "Woodstock" model. I usually test a CRT before doing anything else on a set just after I take the back off.
As soon as the heater warmed up, I saw the purple glow in the electron gun and thought I had a gassy tube, even more so when the meter pegged and the current limiter lamps lit full brightness.
I went as far as looking up this kinescope in my 1968 RCA tube manual and could not find it listed there.
Then I pulled out my other tester, the B&K 445 which is NOT recommended to rejuvenate anything, and looked up the CRT on its chart. Guess what?
Its a low-G2 CRT, which I must have rarely encountered before, otherwise this issue would have presented itself long before on the Heathkit tester with another low G2 CRT.
-Dave G
Old 04-26-2014, 06:00 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Sencore CR-70 FTW.
Old 04-27-2014, 11:09 PM
DavGoodlin's Avatar
Motorola Minion
Yah, If I see a CR70, I'll get it. That Heathkit brought many a 21" round color tube gently back to life, back in the day.
The 445 is a great tester for a BW kine if that's all you need to do.
Moving the switch to check each color gun is a bother.
-Dave G
