Old 05-06-2014, 09:26 PM
Got a neat TV Lamp/Planter
There's not really a forum for these but it's from the early B&W era so here it is.
Got this TV lamp at a local auction, really nice deep green color but I', not sure if the switch or socket is original, seems like it should have a knob that matches.
Also think there's supposed to be a screen to diffuse the light?
It's styled like a late 40's Bakelite set so I'm guessing this is from the late 40's very early 50's.
Can't find one like this on eBay or Google right now so if anyone has one that's intact I'd like to know what is missing from mine, also who the maker was. There's a number on the back but no makers mark.
Old 05-06-2014, 09:27 PM
bigaudioal's Avatar
That's really neat!
-Al
Old 05-06-2014, 11:04 PM
Looks like it should have a frosted screen, all right. If you don't want a plain screen, I wonder if Kinko's (aka FedEx Office) has sheets of whitish acetate that you could print on? Then your light could display anything from your favorite test pattern to the Stooges, etc. Alternatively, you could print onto clear acetate and back that with a thin frosted sheet of something.
I would use a frosted bulb behind the screen, as well, for maximum diffusion. Think low, low wattage. The most practical TV lamps are those that project diffuse light against the wall behind the TV, not a bright light into your eyes competing with the TV image.
Phil's Old Radios
Old 05-06-2014, 11:29 PM
What happened to that lamp? In addition to one knob (the one on the power switch) being mismatched to the other one, the diffuser screen is missing. Did whomever had this lamp before you accidentally break the screen? That's all that stands between you and having a lamp that will work the way its maker intended, unless the bulb is also broken or burned out. Replacements should be easy to find; I think this lamp uses a standard incandescent Edison-base bulb, the kind that's being phased out in the US (in fact has been phased out, as of January 1 this year) in favor of energy-efficient LED and CCFL bulbs. It might not be a bad idea to replace the original bulb in your lamp with an energy-efficient one, although standard bulbs are still available, albeit in short supply.
Replacing the original bulb with a CCFL or LED one will also give you one less bulb to replace for the next few years, as these bulbs can last ten years or more. On Insignia's website (www.insigniaproducts.com), they advertise a bulb that will last 20+ years; this is probably an LED type, as I don't see CCFLs lasting quite that long. I have a CCFL bulb in a table lamp here; the bulb must be over five years old and still works, although it flickers every once in a while when I turn on the lamp at sundown, so it may well be reaching the end of its useful life. I had a CCFL in my other table lamp; that bulb burned out after five years or so. Both bulbs have the "GE" logo on the base, but I'm sure they were not made by the original General Electric Company, which for years had a bulb factory in suburban Cleveland. Chances are better than even that these "GE" branded CCFLs are made offshore, like everything else these days. Grrrr.
Old 05-07-2014, 08:11 AM
WISCOJIM WISCOJIM is offline
I found one for you! I Googled TV shaped lamp under images, and this one is the 16th hit on the first page:
https://s-media-cache-ec0.pinimg.com...bff12577af.jpg
Old 05-07-2014, 08:25 AM
Cool, thank you.
It looks like the switch is original. I guess I can make something to replace the missing screen.
Old 05-07-2014, 09:52 AM
John Marinello's Avatar
<-- "Byron"
Hi Eric, I have seen those on the 'bay in the past, but they never include
the planters. What you found is rare. Nice!
Old 05-11-2014, 01:56 PM
Olorin67 Olorin67 is offline
Cool find, If it was mine, id replace the missing screen with a test pattern immage.
