Old 05-08-2014, 01:18 PM
pac.attack76's Avatar
Stuck in the past
RCA XL-100 model GKR688P October 1984 CTC-120 25" console rescued
Picked this one up yesterday curbside sitting next to an old couch. Tv was dirty and cleaned up nicely. Runs good. Just has a blank space at the top of screen about 1" down and a space at bottom maybe 1/4". I used to know what causes this but its been awhile. Tried to get pics up but having trouble.
Old 05-08-2014, 02:19 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Same sort of problem I'm having with my 1978 19" XL-100, which I'm yet to diagnose.
Old 05-08-2014, 03:17 PM
Try adjusting the vertical size control on the back of the chassis. Besides this, those '80's RCA's rarely had vertical failures.
Old 05-09-2014, 07:50 AM
Dont remember any vert problems on the CTC120 but
probably an electrolytic.
Jons earlier set if it is the chassis I am thinking of had
2) 220 K ohm & a transistor that was very common vert
problem. Symptoms were small pix with some retrce lines IIRC.
Old 05-09-2014, 11:49 AM
Stuck in the past
No retrace lines here. Just the black area at top and barely at the bottom.
Old 05-09-2014, 02:18 PM
Jon A.'s Avatar
Thanks for the info, I've got to pull the back and check exactly what chassis it has. I turned it around to check the label for now, model is FC 444 W.
Old 05-12-2014, 04:08 PM
Rod Beauvex Rod Beauvex is offline
The lead ear.
Pictures?
Old 05-17-2014, 05:06 PM
Jon A.'s Avatar
Chassis in mine is a CTC88AC. Is that the one you're thinking of? If so, where are the suspect resistors and transistor?
Old 06-04-2014, 08:03 PM
Stuck in the past
Turns out it was nothing. Been using the set every night with my CED player and couldn't be better.
