Old 05-12-2014, 12:09 AM
Harvestman's Avatar
Harvestman Harvestman is offline
Cassette Collector
One way of doing things...
"This set of photographs comes from Martin Perrett. The date is, most likely, July 1987 and the van is at the British Grand Prix at Silverstone (Nigel Mansell won). The director, Keith Mackenzie, wanted the ability to record all cameras for replay, and the setup below was a cost effective solution with 15 VHS machines, thirteen to record (one per camera), one for replay and a switchable input machine for record overlap. In later years Beta SPs were used as the VHS quality was not that good!"
"Martin explains:
'I had 15 or so VHS machines that would go straight from record to fast rewind 'in vision'. This allowed you to see the 'event' as you rewound. This was then replayed via a TBC to real VT and they did the on air replay. Meanwhile the camera was being recorded on another VHS machine via a video matrix. All this had to be done before the cars came around again as then it would be history. We had 7 replays in the first race we tried it out on, two from the same camera but via different VHS machines. The system only lasted one Grand Prix as people did not like the fact that non broadcast equipment was being used.'"
The communications panel
http://www.vtoldboys.com/gpreplay.htm
I'm rather surprised that they used VHS for this and not Beta...? Still an innovative way of getting things done.
Punctuation: the difference between "help! murder! police!" and "help murder police"
Old 05-12-2014, 10:22 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Redneck engineering at its best there.
Old 05-12-2014, 10:34 AM
CoogarXR's Avatar
CoogarXR CoogarXR is offline
I bet it was hot in there...
Old 05-12-2014, 01:07 PM
Harvestman's Avatar
Cassette Collector
And here is the setup from four years later (also at Silverstone) with Beta SPs...
http://www.vtoldboys.com/mob1990.htm
Could use a couple of those myself.
Old 05-12-2014, 09:13 PM
Dude111 Dude111 is offline
Analogue is Awesome
Quite interesting indeed!!
