Old 05-15-2014, 05:55 PM
danwalker88 danwalker88 is offline
KY Predicta Princess
I've got a red predicta everything is there UHF knob and antenna. The thing is filthy inside and out. I do not have much knowledge in old electronics. One question can I use a 7.5 ohm 5 watt nos fusistor? The old one was deteriorated. Also is there anyone in KY that may be able to give me some guidance or assistance in restoration? Thanks.
Old 05-15-2014, 06:12 PM
Where in KY ?
Old 05-15-2014, 06:49 PM
Jon F's Avatar
Jon F Jon F is offline
Better to just use a 5W resistor and fuse in series than pay for an NOS part that could be deteriated due to time.
Old 05-15-2014, 07:05 PM
shameless plug
https://www.youtube.com/watch?v=PbKmydNJzg0
that is the 1st of many on a recent one I did. I think I ended up with 10 parts, some are pretty short so does not take too long.
also look for banderson on youtube.
Old 05-15-2014, 07:07 PM
I'm in Richmond KY. How do I go about making this with an inline fuse? Thanks
Old 05-16-2014, 07:45 PM
Just connect a resistor in series with a 1 amp fuse as shown in the lower right. If you have any dud tubes lying around, salvage the base pins. Then attach to the ends so it will mount like the real deal shown at the top.
Old 05-16-2014, 09:37 PM
Thank you so much for the photo that helps me much!
Old 05-19-2014, 08:38 PM
So my B&K 465 crt tester came in the mail today and my predictas 2 V tube passed all the tests!
Old 05-19-2014, 11:54 PM
Cool. Good luck with the restoration
